1-wire reading from several 1-wire buses
Posted: Monday 05 November 2018 21:52
by eriksson25
Hi. Need help. Uses Domotics 4.9700 on rpi
I am in need of several 1 wire buses (several big but independent star buses). I have solved it with Device tree so now I have 4 buses on 4 different gpio pins. They are labeled w1_bus_master(1-4)
So everything is fine, except that only one is identified by domoticz. How can I solve this?
Have been searching without finding anything.
/KG
Re: 1-wire reading from several 1-wire buses
Posted: Tuesday 06 November 2018 21:36
by eriksson25
What I have found so far is
The source file 1WireByKernell.cpp needs to be edited.
This part
bool C1WireByKernel::IsAvailable()
   //Check if system have the w1-gpio interface
   std::ifstream infile1wire;
   std::string wire1catfile=Wire1_Base_Dir;
   wire1catfile+="/w1_bus_master1/w1_master_slaves";
   infile1wire.open(wire1catfile.c_str());
   if (infile1wire.is_open())
      infile1wire.close();
      return true;
   return false;
Now it looks only in w1_bus_master1
It needs to look in all bus_master, or in a other file allredy making a list of all availeble 1wire devices.
Found a sample code for this. https://www.raspberrypi.org/forums/view ... p?t=107894
But dont know how to get them together and runing... Anyone?
void C1WireByKernel::ThreadBuildDevicesList()
	std::string catdir=Wire1_Base_Dir;
	std::string catfile1=catdir+"/w1_bus_master1/w1_master_slaves";
	std::string catfile2=catdir+"/w1_bus_master2/w1_master_slaves";
	std::string catfile3=catdir+"/w1_bus_master3/w1_master_slaves";
	std::string catfile4=catdir+"/w1_bus_master4/w1_master_slaves";
	std::ifstream infile;
    std::ofstream fileOut("/home/pi/domoticz/Tempgivare.txt", std::ofstream::out);
	std::string sLine;
   for (DeviceCollection::iterator it=m_Devices.begin();it!=m_Devices.end();++it) {delete (*it).second;}
   m_Devices.clear();
   infile.open(catfile1.c_str());
	if (!infile.is_open())
      return;
     while (!infile.eof())
      getline(infile, sLine);
      if (sLine.size()!=0)
		fileOut <<(sLine)+"\n";
   sLine="";
   infile.close();
   m_Devices.clear();
   infile.open(catfile2.c_str());
      return;
   infile.close();
   m_Devices.clear();
   infile.open(catfile3.c_str());
      return;
   infile.close();
   m_Devices.clear();
   infile.open(catfile4.c_str());
      return;
   fileOut.close();
   infile.close();
	std::string catfile="/home/pi/domoticz/Tempgivare.txt";
   m_Devices.clear();
   infile.open(catfile.c_str());
      return;
   Locker l(m_Mutex);
         // Get the device from it's name
         _t1WireDevice device;
         GetDevice(sLine, device);
         switch (device.family)
			case high_precision_digital_thermometer:
			case dual_channel_addressable_switch:
			case _8_channel_addressable_switch:
			case programmable_resolution_digital_thermometer:
            m_Devices[device.devid]=new DeviceState(device);
			_log.Log(LOG_STATUS,"1Wire: Added Device: %s",sLine.c_str());
            break;
         default: // Device not supported in kernel mode (maybe later...), use OWFS solution.
			_log.Log(LOG_ERROR,"1Wire: Device not yet supported in Kernel mode (Please report!) ID:%s, family: %02X",sLine.c_str(),device.family);
            break;
   infile.close();
Posted: Saturday 27 July 2019 0:51
by bh999
Hi eriksson25,
Did you ever get this working?
Tonight I changed my setup from a single bus (because I have been experiencing issues) to multi.
I've added:
dtoverlay=w1-gpio,gpiopin=4
dtoverlay=w1-gpio,gpiopin=17
dtoverlay=w1-gpio,gpiopin=18
dtoverlay=w1-gpio,gpiopin=22
dtoverlay=w1-gpio,gpiopin=23
dtoverlay=w1-gpio,gpiopin=24
dtoverlay=w1-gpio,gpiopin=27
to the /boot/config.txt and I can see the devices on the OS:
ls /sys/bus/w1/devices/
28-000003840085  28-031561c83bff  28-051686668cff  28-0516a50d12ff  w1_bus_master1  w1_bus_master3  w1_bus_master5  w1_bus_master7
28-031561c707ff  28-0416a4de5bff  28-0516866992ff  28-0516a50e14ff  w1_bus_master2  w1_bus_master4  w1_bus_master6
but domoticz is only seeing 1 :(
2019-07-26 23:37:50.048  Status: 1Wire: Added Device: 28-0516a50e14ff
Which according to dmesg is on w1_bus_master1
[    4.018533] w1_master_driver w1_bus_master1: Attaching one wire slave 28.0516a50e14ff crc 84
[    4.028293] w1_master_driver w1_bus_master2: Attaching one wire slave 28.031561c707ff crc 59
[    4.075918] w1_master_driver w1_bus_master6: Attaching one wire slave 28.0416a4de5bff crc f6
[    4.078346] w1_master_driver w1_bus_master5: Attaching one wire slave 28.051686668cff crc f1
[    4.132277] w1_master_driver w1_bus_master7: Attaching one wire slave 28.031561c83bff crc 66
[    4.217473] w1_master_driver w1_bus_master3: Attaching one wire slave 28.000003840085 crc 2c
[    4.312789] w1_master_driver w1_bus_master5: Attaching one wire slave 28.0516a50d12ff crc 90
[    4.444676] w1_master_driver w1_bus_master5: Attaching one wire slave 28.0516866992ff crc b5
Looks exactly like the issue you were having.
Thanks,
Posted: Saturday 07 December 2019 23:06
by MFxMF
I had same issue.
Problem has been solved in the domoticz beta.
