Scene trigger not working
Posted: Monday 05 November 2018 17:51
I have been reading through the forums but cannot seem to figure out why this is not working.
I have a scene which turns on the light which is working fine. Now I would like to add a timer to it let's say 10 minutes. I have updated the scene and all works after 10 minutes the light shuts off as per timer.
also tested this using:
http://192.168.1.4:8080/json.htm?type=c ... itchcmd=On
I would like to have this button on my iphone so accoording to the instructions i created a virtual device with type switch on/off:
On action: http://192.168.1.4:8080/json.htm?type=c ... itchcmd=On
Off Action: 600 (equal to my to my scene 10 minutes)
I reduced all to 10 sec for my testing, hoever it does not work when i press the scene in the webif.
virtual switch goes to "On" light does not turn on as per On action command
After 10 seconds (as per instruction) the dummy switch goes to Off
I tried:
http://192.168.1.4:8080/json.htm?type=c ... cmd=Toggle
http://192.168.1.4:8080/json.htm?type=c ... tchcmd=Off
but none of these work "On Action" however they all work through the browser, any ideas?
Cheers,
Hemant
I tried:
Cheers,
Hemant
