Geting data form table
rkarolek
Post by rkarolek »
Hi id like to declare local table variable, and get data depends other variable,
Is it possible to do it?
i try something like that but w/o success :(
local LED_Sunny    = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}
  	timer = {'every minutes'}    --uruchomienie skryptu co minute
   logging = {
       level = domoticz.LOG_INFO,
       marker = "A100_test"
   execute = function(domoticz)
       domoticz.log('function ')
	Time = domoticz.time.rawTime
	HH = domoticz.time.hour
	MM = domoticz.time.minutes
	domoticz.log('hour   ')
	domoticz.log(HH)
	domoticz.log('min   ')
	domoticz.log(MM)
    domoticz.log('LED   ')
    domoticz.log(LED_Sunny(HH))
in log i got this msg
2018-11-03 13:03:00.378 Status: dzVents: Error (2.4.6): A100_test: ...domoticz/scripts/dzVents/generated_scripts/A100_test.lua:32: attempt to call upvalue 'LED_Sunny' (a table value)
any idea?
Re: Geting data form table
rkarolek wrote: Saturday 03 November 2018 13:09 Hi id like to declare local table variable, and get data depends other variable,
any idea?
Yes, it is possible and you were very close.
Look at the example below for right syntaxis. Be aware that a Lua array (which are in fact a table indexed with sequential integers) start with 1 when indexed implicitly.
what you do with LED_Sunny = {0,0,0,0} is telling Lua
LED_Sunny[1] = 0,
LED_Sunny[2] = 0,
LED_Sunny[3] = 0,
LED_Sunny[4] = 0
   logging = {
        local LED_Sunny    = {1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,0,0,0,0,0,0,0}
        LED_Sunny[0] = 0        -- 0 is a "special"case" as Lua arrays start with 1
        domoticz.log(HH)
        domoticz.log(MM)
        domoticz.log('LED   ' .. LED_Sunny[HH])
rkarolek
Post by rkarolek »
tyvm, it works
but cant understand diference :( problem was lack of [0] table's value or declare local varible on start script?
No. Real reason was your use of (HH), where it should have been [HH]
rkarolek wrote:tyvm, it works
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
rkarolek
Post by rkarolek »
realy?
lol, omg....
tyvm once more for your time
