EQ-3 bluetooth radiator thermostat Domoticz control
Posted: Friday 02 November 2018 9:59
by inzuno
I brought some EQ-3 bluetooth radiator thermostat and I wanted to control it with Domoticz.
But I had some issues pairing bluetooth on my PI so I post here my method.
First you need to download this script: https://github.com/Heckie75/eQ-3-radiator-thermostat
put it in a folder (in this example home/pi/eq3) and follow instructions of initial setup in readme.
Go in the folder where you put the script and try to run the command.
./eq3.exp
if you can read the help, it's ok.
After we need to pair the device, I didn't manage to pair with the initial setup of the scrip.
Here is my method:
start bluetooth control
bluetoothctl
set controller to be pairable
pairable on
discover devices
scan on
You should see MAC address with name CC-RT-BLE write it down or copy to clipboard to pair the device.
Set radiator thermostat in pairing mode by long press the center button until you see PAIr
(The code displayed after is a fake, don't pay attention to it)
Pair the device on the Pi with the command:
pair MAC_CC-RT-BLE
If pairing is successful the device is permanently connected and we need to disconnect it to be usable:
disconnect MAC_CC-RT-BLE
disable pairable mode
pairable off
exit bluetooth control
quit
Now you go in the script folder and play:
./eq3.exp MAC_CC-RT-BLE sync
You can see thermostat status?
Cool! But we still don't have control in Domoticz...
So I created a dummy selector switch and put this in selector actions:
0	script:///home/pi/eq3/eq3.exp MAC_CC-RT-BLE temp 5.0
10	script:///home/pi/eq3/eq3.exp MAC_CC-RT-BLE temp 17.5
20	script:///home/pi/eq3/eq3.exp MAC_CC-RT-BLE temp 18.0
30	script:///home/pi/eq3/eq3.exp MAC_CC-RT-BLE temp 18.5
40	script:///home/pi/eq3/eq3.exp MAC_CC-RT-BLE temp 19.0
50	script:///home/pi/eq3/eq3.exp MAC_CC-RT-BLE lock
60	script:///home/pi/eq3/eq3.exp MAC_CC-RT-BLE unlock
70	script:///home/pi/eq3/eq3.exp MAC_CC-RT-BLE boost
80	script:///home/pi/eq3/eq3.exp MAC_CC-RT-BLE boost off
\o/
If anyone could make a plugin to have a nice thermostat switch for this it would be really nice :D
As i'ts my first new post, if there is any mistake or better ways to do what I did, please don't yell at tell me!
Re: EQ-3 bluetooth radiator thermostat Domoticz control
Posted: Thursday 17 January 2019 19:36
by sebretu
Edit file thermo-livingroom.sh write MAC adresse of yours EQ3
than make a dummy selector switch and put this in selector actions:
0	            script:///home/pi/eq3/thermo-livingroom.sh temp  5.0
10	            script:///home/pi/eq3/thermo-livingroom.sh temp 17.5
20	            script:///home/pi/eq3/thermo-livingroom.sh temp 18.0
30	            script:///home/pi/eq3/thermo-livingroom.sh temp 18.5
40	            script:///home/pi/eq3/thermo-livingroom.sh temp 19.0
50	            script:///home/pi/eq3/thermo-livingroom.sh lock
60	            script:///home/pi/eq3/thermo-livingroom.sh unlock
70	            script:///home/pi/eq3/thermo-livingroom.sh boost
80	            script:///home/pi/eq3/thermo-livingroom.sh boost off
For me its working fine
