Fibaro Double Switch 2 (FGS-223) only 1 switch works
Posted: Thursday 01 November 2018 21:27
I just installed a new Fibaro Double Switch 2 (FGS-223).
Everything seems to work fine, however switching the left switch doesn't work in Domoticz. The right switch does work. Manually switching does work for both switches and the power usage is shown correct as well in Domoticz.
However, when I go to the OpenZWave Control Panel via the Hardware page and I click on the switch and subsequently I click on ON or OFF behind the switch that isn't working through Domoticz, and that is actually working.
Is this a bug? And can I fix it myself?
Thanks in advance!
Thanks in advance!
