Suggestions regarding recent Domoticz App updates (oct 2018)
Posted: Thursday 01 November 2018 20:38
First I would like to comment that I like the new looks of the Domoticz Lite app (Android 8 / Samsung S7).
A couple of suggestions to improve it even more (from my perspective though
1. I prefer the old/previous color chooser for RGB lights, this is because you were able to select the exact same colors every time. With the new one this is impossible. The app also doesn't remember anymore the color that you have set. It did before. (improvement)
2. The name for the dashboard button called 'Switches' is confusing (in Dutch). The old name 'Dashboard' would be more appropriate. (text bug) -> fixed
3. When you turn on a RGB light from the "Dashboard" it says "Status: On". When you then go to "switches" it says "Status: Set Level 48%". When you then go back to "Dashboard" it also says "Status: Set Level 48%". (bug)
4. After step 3, when you move the brightness slider (still on Dashboard), the percentage in the upper right corner increases/decreases. The percentage behind "Status: Set Level: 48%" doesn't change. (bug)
5. After step 3 and/or step 4, when you go to "Switches" and move the brightness slider, the percentage doesn't increase/decrease in both the upper right corner nor the "Status: Set Level: 48%". (However there is the short popup message "the value for .. has changed to 55%".) (bug)
