update switch without action
Posted: Thursday 01 November 2018 11:36
by poudenes
Hi All,
Lost it... How can i update a switch or bulb without the actual actoin to turn it on or off?
Cheers,
Peter
Re: update switch without action
Posted: Thursday 01 November 2018 12:56
by waaren
poudenes wrote: Thursday 01 November 2018 11:36
Hi All,
Cheers,
Peter
viewtopic.php?f=4&t=24037&p=185345&hili ... ed#p185333
Posted: Thursday 01 November 2018 14:22
by poudenes
You are the master! Thanks
Verzonden vanaf mijn iPhone met Tapatalk Pro
Posted: Saturday 03 November 2018 9:01
by poudenes
Maybe a idea to implement this into dzvents?
Then it's easy to use instead of a http link
Cheers
Posted: Saturday 03 November 2018 9:56
by waaren
poudenes wrote: Saturday 03 November 2018 9:01
Maybe.., If you can describe the situation for what it would be used .
Posted: Saturday 03 November 2018 11:11
by poudenes
waaren wrote: Saturday 03 November 2018 9:56
In My situation: I turn on a group of bulbs (bulbAll) and 1 of the bulbs i turn into a different color. Faster then turn every bulb separate first and change color.
But when i change the color of 1 bulb the BulbAll device goes off ( have the BulbAll as slave in my other bulbs because when 1 of the bulbs in the group is go off then BulbAll must go off as well(not all bulbs are on)
So i want a action when BulbAll goes on, change 1 bulb inside the group then Turn on BulbAll device only without action.
I have some triggers based on BulbAll. Or i need to change the trigger and look to Bulb1 Bulb2 and Bulb3 is on or off.
Posted: Saturday 03 November 2018 14:29
by waaren
poudenes wrote: Saturday 03 November 2018 11:11
What happens if you add the option .silent() in the dzVents command that changes the color?
Posted: Tuesday 06 November 2018 20:54
by poudenes
waaren wrote: Saturday 03 November 2018 14:29
No is not working.
