Another sun position calculator
Posted: Wednesday 31 October 2018 19:07
I've just stumbled across this Python script for calculating sun position: https://github.com/s-bear/sun-position.
It's based on an algorithm which claims to calculate "the solar zenith and azimuth angles in the period from the year −2000 to 6000, with uncertainties of ±0.0003°".
Save it asIt runs happily on a RPi under Python 2.7 (may need some changes for Python 3.x).
I've created a separate Python script to read azimuth and zenith values from sunposition.py (zenith is converted to altitude: altitude = 90 - zenith), and then writes the values to two custom sensor devices in Domoticz:
Save the following script in the same folder as above, and run it with cron at your required frequency.
Save it as
/path_to_python_scripts/sunposition.pyI've created a separate Python script to read azimuth and zenith values from sunposition.py (zenith is converted to altitude: altitude = 90 - zenith), and then writes the values to two custom sensor devices in Domoticz:
- Spoiler: show
