DarkSky "LaCrosse TX3"
Posted: Tuesday 30 October 2018 11:59
by Furry
I have a DarkSky "Temperature" device of subtype "LaCrosse TX3" which reads -17.8C.
Can someone please tell me: what/where is this?
TIA
Re: DarkSky "LaCrosse TX3"
Posted: Tuesday 30 October 2018 13:05
by alanlsmith
Somewhere cold?
But seriously, all the dummy temperature sensors (including Dark Sky) that I have are shown as LaCrosse.
Have you enabled Dark Sky in the hardware section and if so is the location (on the planet) correct?
Posted: Tuesday 30 October 2018 13:47
by Furry
Yes, it's enabled (and all the other DarkSky 'sensors', and the forecast, work correctly), and the location is correct.
Posted: Tuesday 30 October 2018 14:13
by alanlsmith
Oh...
Is that the only Dark Sky temperature sensor and has it been updated recently. Also has any adjustment been applied to it under edit?
Posted: Tuesday 30 October 2018 19:57
by Furry
alanlsmith wrote: Tuesday 30 October 2018 14:13Is that the only Dark Sky temperature sensor...
No, there's also the Temp / Humidity / Barometer sensor, with subtypes "THB1 - BTHR918, BTHGN129".
alanlsmith wrote: Tuesday 30 October 2018 14:13... and has it been updated recently.
Domoticz has been updated many times recently, but I believe this sensor has been there for a long time.
alanlsmith wrote: Tuesday 30 October 2018 14:13Also has any adjustment been applied to it under edit?
Applied to what? How/why would adjustment/edit be done?
Posted: Tuesday 30 October 2018 21:00
by alanlsmith
Furry wrote: Tuesday 30 October 2018 19:57No, there's also the Temp / Humidity / Barometer sensor, with subtypes "THB1 - BTHR918, BTHGN129".
Does the temperature on that read the same as the device you mentioned in your original post.
Furry wrote: Tuesday 30 October 2018 19:57Domoticz has been updated many times recently, but I believe this sensor has been there for a long time.
I meant when was the last update of the temperature device itself.
Furry wrote: Tuesday 30 October 2018 19:57Applied to what? How/why would adjustment/edit be done?
On the device itself in the web ui, click edit and you can enter a plus or minus figure to correct any inaccuracies (normally to correct the output of an actual physical device) I don’t know why this would be changed in your case but it’s worth checking to eliminate it.
