Esp8266 and ds18b20 not working with wall supply
Posted: Monday 29 October 2018 20:11
by juuzo
I have stange problem with my power supply. I have esp8266 connected with two ds18b20 sensors. Data line has 100k pull up resistor. I have ht7333 regulator with capasitors to power whole thing. I have soldered usb cord so i can supply whole thing anywhere. My problem is that I can read sensors only if usb cord is connected to laptop. If I try to supply with 2A wall power supply the sensors fails to read and i get only -127c readings. I assume that my code is totally fine cause it works with laptop power but I have no idea why it’s not working with wall supplies. I have tried with four different wall supplies with no success. Any idea?
Re: Esp8266 and ds18b20 not working with wall supply
Posted: Friday 02 November 2018 17:13
by gerardvs
Most likely the power is despite the capacitors still not stabilized enough. Try a larger cap. Also a 100k pull-up seems a bit high.
Please share the schematic so we could get a better picture.
Posted: Friday 02 November 2018 17:31
by randytsuch
Did you try a different power supply?
I've had problems with cheap Chinese USB power supplies.
You might need to put a cap on the power line to the 18b20s. Maybe try shorter wires to the 18b20 to see if that makes a difference.
Randy
Posted: Tuesday 06 November 2018 11:03
by juuzo
Hi, I have tried with ipad power supply wich I think is good quality. Still not working. Here is shematic (some internal components definitely missing but you get the point). Cables to ds18b20 sensors are 1m long so I don't think those are problem. Is 1000uf capacitor too small?
Posted: Wednesday 07 November 2018 10:59
by gerardvs
R1 is a bit high. Try a 4K7 resistor.
Posted: Wednesday 07 November 2018 11:19
by juuzo
But I don't understand why resistor would be problem if system works with laptop usb connector. I will try smaller resistor.
Posted: Wednesday 07 November 2018 19:36
by gerardvs
This is called a "process of elimination" ;)
Posted: Thursday 08 November 2018 16:25
by juuzo
Ok, i tried with 4,7kohm and two 4,7kohm resistors paraller but no succes. What would be next method of elimination? Sometimes I get readings out of one of the sensors but not both.
Posted: Thursday 08 November 2018 19:48
by gerardvs
4,7k is the normal value so you can eliminate that.
Hopefully you have a oscilloscope on hand to check how "clean" the 3.3V is. If not you could set you DM on AC and see if there is some ripple. If there is a high freq. ripple, only a cap is not enough, you have to add a small coil to get an LC drain.
Also the ESP8266 can use more than 200mA when connected. The max current of the HT7333 is 250mA so you are really on the limit. Not sure but also something you could check of test another regulator.
It is a step by step process. The circuit is really simple. I have many esp8266 with 1820 running on old scrap mains adapters. They all work well but they all use a 500-1000mA regulator (to be on the safe side).
Good luck, it must be something simple :-)
Posted: Monday 12 November 2018 7:55
by juuzo
That regulator thing is good point. I bought ht7333 just because of battery powered sensors but with wall supply I can use some other regulator. I will buy few regulators that can supply more current and test with those.
Posted: Thursday 22 November 2018 16:04
by juuzo
I tried to power ds18b20 sensors straight from 5v usb line and ht7333 only supplying esp8266. So problem is not ht7333. Still sensors reading -127c... I have no clue what I try next...
Posted: Wednesday 28 November 2018 6:53
by juuzo
I made another esp for my co worker and it works flawlessly with 8 ds18b20 installed to it. I think that my problem must be the sensors itself. I have to try with other sensors now.
Posted: Wednesday 28 November 2018 16:19
by gerardvs
Thanks for reporting back on this.
Maybe the sensor is a bit sensitive on 3.3v. Most likely a Chinese clone(?) These components usually work fine unless you are on the boundary of the specs.
