Turn the switch off when script finishes
Posted: Saturday 27 October 2018 22:10
by mirikbb
I have a dummy switch. When I turn it ON, it executes associated bash script.
Currently, when the script finishes, the switch will stay in ON position.
I am searching the way how to turn the switch OFF, automatically when the script finishes.
Many thanx for help.
Re: Turn the switch off when script finishes
Posted: Saturday 27 October 2018 22:25
by devros
hello just add curl json command at end of the script
something like this
curl '
http://YOURIP/json.htm?type=command&par ... tchcmd=Off'
Posted: Saturday 27 October 2018 23:11
by mirikbb
brilliant devros! Many thanx for navigating me to the solution.
as I have got 'Unauthorized' response to curl, I just had to extend the url with my relevant encoded name/password, based on the response from this thread
viewtopic.php?t=19949
Posted: Sunday 28 October 2018 0:28
by waaren
mirikbb wrote: Saturday 27 October 2018 22:10
If you want to be sure that the switch return to the Off state even when the start- or execution of the bash-script fails before it reach the curl command, as explained by devros, you could set the Off delay to n seconds in the edit section of the switch (to be reached via the edit button on the device at the switches tab)
