Cannot configure Aeotec ZW100 Multisensor 6
Posted: Wednesday 24 October 2018 14:22
by obruchez
I have:
- 4 Aeotec ZW100 Multisensor 6 devices
- 3 Aeotec ZW100 Multisensor 6+ devices (notice the + after the 6!)
When I select one of the "6" devices, I don't see any parameter in the configuration (i.e. there's no configuration to edit), whereas when I select one of the "6+" devices, I see all the usual parameters. Is this expected? Or is it a bug?
Another question: I'm trying to completely disable the LEDs of my 7 Multisensor devices. I've been able to set the LED parameter to "Completely disable" for my 3 "6+" devices, but it doesn't seem to work. Any idea what's wrong? Is it a bug in the device, in Domoticz or elsewhere?
Thanks a lot for your help!
Re: Cannot configure Aeotec ZW100 Multisensor 6
Posted: Sunday 30 December 2018 12:32
by obruchez
Does anybody know how I could debug/help with this?
Is this likely a bug in Domoticz or in the OpenZWave layer?
Posted: Sunday 30 December 2018 16:51
by LouiS22
obruchez wrote: Wednesday 24 October 2018 14:22
I have:
The+ signal is for zwave plus devices (newer chip, greater coverage with less power consumption).
Check openzwave repo here:
https://github.com/OpenZWave/open-zwave ... fig/aeotec
Have a look for your model's number. If it's present, the xml file could be incorrect, or simply copypaste from a different model. Inspect it and compare the values from your user's manual. If you find any difference, then you have to commit it into the repo and it will be populated to the main branch and eventually into domoticz. You can also test it locally, but it needs some xml editing (you have to create an entry at manufacturer_specific.xml and another at the aeotec folder) and also excluding and including again the device.
