Zooz USB Stick ZST10 and Sensor ZSE40 Verified Good!
Posted: Tuesday 23 October 2018 13:14
Just added a ZOOZ USB Z-wave Plus S2 Stick (ZST10) to a fresh install of Domoticz and did the openzwave setup, and can vouch for it working flawlessly.
Installed Ubuntu MATE 18.04, Domoticz (via sudo curl -L install.domoticz.com |bash ) then installed OpenZWave using the directions posted here ... https://github.com/mozilla-iot/wiki/wik ... -OpenZWave and restarted the system and added the stick through Hardware.
Hardware was a older laptop, but will be replicating it on a RPi3 this weekend and don't expect any issues.
Also can report that the ZOOZ Z-Wave Plus 4-in-1 Sensor ZSE40 version 2.0 works great with Domoticz/OZW as well. Even the 'control panel' in Domoticz supports the proper commands to change settings if needed.
Hope this helps someone in the future having questions about compatibility or something.
