KNX Hardware support
Posted: Tuesday 23 October 2018 9:41
by emme
Would anyone interested in developing a KNX Hardware connector (IP) for Domoticz?
I can provide my (poor) experience and certification, but I'm totaly blind in coding
The system is almost a telegram protocol based on Groups, Acknoledge and data....
thanks
ciao
M
Re: KNX Hardware support
Posted: Tuesday 23 October 2018 10:21
by solidum90
Hi/Ciao emme,
I've Vimar By-Me domotic system, it's based on EIB topology, the same KNX bus.
I'm using this device
http://guidopic.altervista.org/alter/knxgate.html (guido, another italian
) it uses an esp8266, it's very very cheap.
With my own little system that acts as an interface to / from domoticz..
It is now a year that I have in mind to rewrite Guido's ESP8266 firmware basing on MQTT but I have never found the time to do it.
Otherwise there are gateway knx that are a TCP-IP modbus server but they are quite expensive (2/300€)
Posted: Tuesday 23 October 2018 10:28
by emme
Ciao,
that links refer to a gateway... which is good but I already have the USB and IP Interface, I meant to develop a fully working hardware connector that could handle the KNX telegram (in/out) and link a device to a group based on its datapoint.
Ciao
M
Posted: Friday 25 January 2019 23:58
by papoo
hello emme
did you manage to inter connect simply knx and domoticz?
Posted: Monday 04 February 2019 8:04
by emme
Yes, I did, using NodeRed and only for DPT1 and 5
I made a flow between KNX and Domoticz (MQTT) with a reference map that link KNX group ==> Domoticz action and viceversa
It's running since 2 month with no special issues... well sometimes it loops on a specific lamp which assume it' a status group error in the ETS project
Posted: Monday 04 February 2019 13:25
by papoo
thanks for your response.
Posted: Monday 11 February 2019 21:53
by papoo
Please, can you tel me which node do you use for that?
