Error waterflow script
remko2000
Post by remko2000 »
I try to implant this code:
-- IDX Waterflow
jIDX = 235
-- Begintijd in uservariables zetten
if  (uservariables['begin'] == 0)
    then
        -- print ("begin instellen")
        commandArray['Variable:begin'] = tostring(1)
        commandArray['Variable:begintijd']= tostring(os.time())
-- Decimalen
function round(num, numDecimalPlaces)
   local mult = 10^(numDecimalPlaces or 0)
   return math.floor(num * mult + 0.5) / mult
-- timedifference
function timedifference(s)
      year = string.sub(s, 1, 4)
     month = string.sub(s, 6, 7)
     day = string.sub(s, 9, 10)
     hour = string.sub(s, 12, 13)
     t1 = os.time()
    return difference
-- Script
if (devicechanged['GPIO Watermeter'] == 'Off')
   then
       -- print ("Watermeter gaat naar Off")
       btijd = uservariables['begintijd']
       duur = os.time() - btijd
       lpm = 60 /duur
       -- print (lpm)
       lpm = round(lpm, 2)
       -- print (btijd)
       -- print (os.time() - btijd)
       -- print (os.time())
       -- print (duur)
       -- print (lpm)
       commandArray['UpdateDevice'] = ''..jIDX..'|0|'..lpm..''
        -- Keep a live device and set flow to zero
        if (timedifference(otherdevices_lastupdate["GPIO Watermeter"]) > 300)
           then
               -- print("tijd langer dan 300")
               flow = 0
               -- commandArray['Variable:begintijd']= tostring(os.time() - 300)
               commandArray['UpdateDevice'] = ''..jIDX..'|0|'..flow..''
But I get this error:
‘ Error: EventSystem: in Waterflow: [string “commandArray = {}…”]:22: bad argument #1 to ‘sub’ (string expected, got nil)’
line 22= 'year = string.sub(s, 1, 4)'
I use domoticz V4.10007 on a raspberry pi 3.
I searched for a solutions but I'm stuck. What can I change in this code?
remko2000
Re: Error waterflow script
Post by remko2000 »
I tried to verify my code with a codechecker and get back:
line 7: attempt to index global 'uservariables' (a nil value)
stack traceback:
t.lua:7: in main chunk
[C]: ?
I'm a beginner with LUA so I do not know how to solve this? Is there someone who can help me?
juuzo
Post by juuzo »
You are trying to parse string in variable s and you dont seem to have any variable s. what time difference you would like to calculate?
remko2000
Post by remko2000 »
I'm trying to follow this ' how to' :
https://ehoco.nl/waterflowmeter-in-domoticz/
I think it is the difference between the moment the water starts to run and the water stops again.
I have followed exactly the how to, so it is strange that it does not work
juuzo
Post by juuzo »
Okay now i found it. So here you read that timedifference(s) timedifference(otherdevices_lastupdate["GPIO Watermeter"]
Do you have device called GPIO Watermeter? Note this is case sensitive.
