evohome web api not showing my devices
Posted: Sunday 21 October 2018 20:32
by checkingnl
hi
First time here, searched a lot on my issue, but can'f find anything close to it. So here it comes:
I have domoticz running on a synology
I added hardware Evohome with WEB api. So that went well
It added devices in the Setup/Devices list, so that was promising.
In the log I see
2018-10-21 20:27:35.867 (Evo Thermostat) fetch data from server
2018-10-21 20:28:37.028 (Evo Thermostat) fetch data from server
So it is fetching data, again very promising.
BUT I cannot see any device on temperature tab, it still says: No Temperature sensors found or added in the system...
So i'm lost, no logs with any errors or whatsoever, no hint of something went wrong. HOW can i get devices to show up on the usefull locations outside the SETUP menu. I really love some hints/help to get nice blocks on any other page to start working with the data.
anyone to chip in?
Re: evohome web api not showing my devices
Posted: Sunday 21 October 2018 23:44
by waaren
checkingnl wrote: Sunday 21 October 2018 20:32
In the log I see
Did you press the small green Arrows on the right side of the device lines on the devices tab to enable them (and name the zones) ?
Posted: Monday 22 October 2018 9:20
by checkingnl
waaren wrote: Sunday 21 October 2018 23:44
In the log I see
I did, as far as i can recall. But after removing and adding two times more and indeed the zones are visible now on the right tabs.. dunno what went wrong.. now next step is HUE bridge not loading bulbs
Posted: Monday 22 October 2018 9:34
by waaren
checkingnl wrote: Monday 22 October 2018 9:20
That might become a challenge if you are on the latest stable.
In 4.9700 adding Hue bulbs or groups does not work. It is solved but the solution is only available in later beta's
Posted: Monday 22 October 2018 9:41
by checkingnl
waaren wrote: Monday 22 October 2018 9:34
do you know what was the issue? i did see somthing on versions in june (beta's).. not seen any fix so far
Posted: Monday 22 October 2018 10:11
by waaren
checkingnl wrote: Monday 22 October 2018 9:41
Pleas have a look
here and
here
Posted: Monday 22 October 2018 11:21
by checkingnl
waaren wrote: Monday 22 October 2018 10:11
Pleas have a look
here and
here
ah.. great, thx a lot.
will need to find if the version used in these
http://www.jadahl.com/domoticz_beta_6.2_python/ is consumable
Posted: Monday 22 October 2018 11:37
by waaren
checkingnl wrote: Monday 22 October 2018 11:21
Pleas have a look
here and
here
You can just use the
latest Beta from Jadahl
Posted: Tuesday 23 October 2018 16:25
by checkingnl
beta works fine indeed. Nice to see beta be usable so far too
next is understanding virtual devices setup
