Control setpoint with PS=1
Posted: Sunday 21 October 2018 10:47
I have a OTGW with nodemcu connected to my boiler. According to the OTGW website http://otgw.tclcode.com/standalone.html#intro it is possible to use the OTGW without thermostat connected.
When I try without connecting domoticz to the OTGW and using the OTMonitor to see what's happening, I can set a control setpoint by using the following url: http://192.168.0.5:8085/command?CS=50. In OTmonitor I can see the result in the messages:
As expected, the CH_enabled flag is set and boiler starts to heat.
I like to this from Domoticz. So I turned on the relay server in OTmonitor config and added the OTGW with LAN connection hardware in Domoticz. This seems to work, because I get a number of devices that actually give temperatures and so on.
But now, PS=1 has been set. Because of this I can no longer use OTmonitor. And now when I use the same url as before to set the Control setpoint I get the following output in the OTmonitor messages:
The control setpoint (second value on last line) is not updated now. So the boiler doesn't do anyting.
Does someone have an idea on how to make this work?
09:43:49.412536 CS: 50.00
09:43:49.721225 R00120000 Read-Data CH water pressure: 0.00
09:43:49.723964 B60120000 Data-Inv CH water pressure: 0.00
09:43:50.516928 R80000100 Read-Data Status: 00000001 00000000
09:43:50.629104 BC0000102 Read-Ack Status: 00000001 00000010
09:43:51.561084 R80190000 Read-Data Boiler water temperature: 0.00
09:43:51.673039 B40191700 Read-Ack Boiler water temperature: 23.00
09:43:52.605103 R90013200 Write-Data Control setpoint: 50.00
09:43:52.713102 B50013200 Write-Ack Control setpoint: 50.00
09:43:53.637121 R80010000 Read-Data Control setpoint: 0.00
09:43:53.741081 BD0010000 Write-Ack Control setpoint: 0.00I like to this from Domoticz. So I turned on the relay server in OTmonitor config and added the OTGW with LAN connection hardware in Domoticz. This seems to work, because I get a number of devices that actually give temperatures and so on.
10:43:30.352924 Command (via websocket from 192.168.0.10:54716): CS=50
10:43:30.434903 CS: 50.00
10:43:35.837218 Command (via relay server, from 192.168.0.5:34304): SC=10:43/7
10:43:35.843057 Command (via relay server, from 192.168.0.5:34304): PR=G
10:43:35.845111 Command (via relay server, from 192.168.0.5:34304): PR=I
10:43:35.846502 Command (via relay server, from 192.168.0.5:34304): PR=O
10:43:35.847778 Command (via relay server, from 192.168.0.5:34304): PS=1
10:43:35.986990 SC: 10:43/7
10:43:43.693674 00000001/00000010,10.00,00000001/00000001,0.00,0/0,20.50,0.00,0.00,20.52,24.00,0.00,0.00,23.00,75/20,0/0,0.00,0.00,0,0,0,0,0,0,0,0
