Script for light to switchOff when TV is on  [Solved]
Posted: Friday 19 October 2018 10:59
by drwurn
I'm trying to make a script to turn off a light when tv is switched on.
When the tv is switched off the light has to go on again.
I'm this far but there is (atleast) one fault at [15:8] '}' expected near 'if'.
Not sure what is going wrong
local timerString = "every 1 minutes between sunset and 23:00"
        on =        { timer   =   { timerString }},
    execute = function(dz)
        local SamsungTV             = dz.devices(48)
        local LampWoonkamer         = dz.devices(3)
        local OnConditionsMet       =   LampWoonkamer.state == "On" and
                                        SamsungTV.state =="On" and
                                        dz.time.matchesRule("between sunset and 23:00")
        if OnConditionsMet then
            LampWoonkamer.switchOff()
            if LampWoonkamer.state == "Off" then
                LampWoonkamer.switchOn()
                if SamsungTV.state =="Off"
                elseif dz.time.matchesRule("between sunset and 23:00")
Re: Script for light to switchOff when TV is on
Posted: Friday 19 October 2018 12:51
by waaren
drwurn wrote: Friday 19 October 2018 10:59 I'm trying to make a script to turn off a light when tv is switched on.
Not sure what you want with the light outside the time the script executes but the end at line 13 does not belong there.
What is the purpose of the logic at line 20/21 ? They niow both miss a "then"
Posted: Friday 19 October 2018 13:54
by drwurn
Hi Waaren,
What I want to accomplish is:
The light goes on at sunset and off at 23:00.
If the light is on, and the tv is switched on, the light has to go off.
When I turn the tv off, the light has to go on again if it's between sunset and 23:00
Posted: Friday 19 October 2018 14:28
by waaren
drwurn wrote: Friday 19 October 2018 13:54 Hi Waaren,
Untested but could be something like
local timerString = "every minute between sunset and 23:01"
local tv          = 48
        on =        {  timer   =   { timerString },
                       devices =   { tv  }},
        local SamsungTV     = dz.devices(tv)
        if dz.time.matchesRule("between sunset and 22:59") then
            if      SamsungTV.state == "On" then LampWoonkamer.switchOff().checkFirst()
            elseif  SamsungTV.state == "Off" then LampWoonkamer.switchOn().checkFirst()
Posted: Friday 19 October 2018 15:26
by drwurn
That works great.
I did read your feedback and your script and modified my own script. Not that I think that my script is better but it's like the first or second script that I write and this way I can learn from my own mistakes instead of copy/paste.
Please tell me what you think of my script, can I improve it somehow?
local timerString = "every 1 minutes between 10 minutes before sunset and 23:01"
                                        dz.time.matchesRule("between 10 minutes before sunset and 23:00")
            if  LampWoonkamer.state == "Off" and
                SamsungTV.state == "Off" and
                dz.time.matchesRule("between 10 minutes before sunset and 23:00") then
Posted: Friday 19 October 2018 17:10
by waaren
drwurn wrote: Friday 19 October 2018 15:26 That works great.
Looks great. One smalle remark/question. Why do you have the first
and
If I understand correctly that part is always true and therewith redundant when using this time trigger.
I fully understand your remark about learning better from trial and error than from copy/paste. I try to find a mix of those for my own learning. I copy/paste almost everything and the trial and error starts when I try to glue the parts together to something that does exactly what I want and when I want it.
Posted: Friday 19 October 2018 18:21
by drwurn
Not sure why I have
and
planted there. Thought it look good there lol, but shall remove it if it's useless there :)
