Venetian EU Blinds
Posted: Friday 19 October 2018 9:20
by bokan20
I have a problem with setting blinds. I can not set "Venetian EU" switch. Attach an image to see how I set it up...
Re: Venetian EU Blinds
Posted: Friday 19 October 2018 9:55
by emme
try with ON/OFF instead of Open/Close
Posted: Friday 19 October 2018 9:59
by bokan20
I tried that. I forgot to mention :(
Posted: Friday 19 October 2018 10:21
by emme
can you describe a bit better the hardware type of the switches and blind?
Posted: Friday 19 October 2018 10:43
by bokan20
Of course,
the device i use for the relay is:
https://denkovi.com/smartden-lan-ethern ... n-rail-box
The electric motor for the blinds is classic 230V. Pictures below...
Posted: Monday 22 October 2018 8:19
by emme
mmh ok...
let's resume...
The 2 relays that operate the motor are NOT a rolling shutter device, but a 2 relay manually (and indipendently) operated....
So... it must be clear that ALL the times you act a movement you MUST deny the other movement:
if you want to go UP you have to open the down contact anche close the open one for a certain amount of time (do NOT leave it closed!!!)
if you want to go DOWN you have to open the up contact anche close the down one for a certain amount of time (do NOT leave it closed!!!)
more... the venetian blind device is a virtual device, not really connected to anything.. correct?
so.. all the time you press the ventian UP/DOWN you have to operate as per upper description (you would have a script running for that)
you have problems operating the venetian (virtual) switch right?
if so... I'll make a try to replicate the scenario... I'll shortly will be in the same situation between a virtual blind object and a KNX shutter device, so it would be almost the same!
ciao
M
Posted: Monday 22 October 2018 11:21
by bokan20
Emma thanks for your suggestions. This morning I wiped out the "Switch, blockly" ... and now I'm working the blind switch.
Switch
Testing...
Off reley
Can you help me to do ON or OFF with the "script" to run from BLOCKY ???
Posted: Wednesday 24 June 2020 20:13
by clemberto
sorry for digging up the thread, but I have almost same hardware setup, and there is a possibility my Blind motor gets power on its 2 phases (Up and Down command simultaneously).
What is the effect of this on blind motor? Is there any protection inside the blinds?
Call me not brave enough to test it myself, but I have a quite huge blind at home; any maintenance on it would be painful.
If anyone has some knowledge...
