COP calculation script
Posted: Wednesday 17 October 2018 8:21
by juuzo
Hi, I'm really new to lua scripting and I'm trying to make simple calculation program that calculates heatpump cop with measured temperatures, power and fan speed. Anyway I'm little stuck on this script. I get error
/home/pi/domoticz/scripts/lua/script_time_COP.lua:5: ']' expected near 'Fan'
So I assume that there is somethin wrong with fan speed reading. Fan speed is simple 6 step switch with values 0 to 60.
time = os.date("*t")
if((time.min % 5)==0)then --Run every 5 minutes
   var1 = commandArray.GetValue(otherdevices_svalues[Heatpump Fan Speed],1)
   if (var1 == 0 or var1 == 10) then
   airvolume = 0
   if (var1 == 20) then
   airvolume = 120
   if (var1 == 30) then
   airvolume = 220
   if (var1 == 40) then
   airvolume = 320
   if (var1 == 50) then
   airvolume = 520
   if (var1 == 60) then
   airvolume = 620
   OutletTemp = commandArray.GetValue(otherdevices_svalues[Heatpump Outlet Temp],1)
   InletTemp = commandArray.GetValue(otherdevices_svalues[Heatpump Inlet Temp],1)
   inpower = commandArray.GetValue(otherdevices_svalues[Heatpump Power/Energy],1)
   outpower = airvolume * 1,293 * 1,01 * (OutletTemp-InletTemp)
   calculation = outpower / inpower
   print( " ####Cop debug: "..calculation)
   COPidx = otherdevices_idx['Heatpump COP']
   commandArray['UpdateDevice'] = COPidx..'|0|'..calculation
Re: COP calculation script
Posted: Wednesday 17 October 2018 8:37
by SweetPants
Try var1 = commandArray.GetValue(otherdevices_svalues['Heatpump Fan Speed'],1)
Posted: Wednesday 17 October 2018 9:26
by juuzo
I got something to work with this script
Now I can read values even though my airflow doesn't update in those if then fields. Biggest problem is now that my energy meter gives values like 300.10;259999 where first value is power what I want and second is energy what I don't need. How do I parse that first number and how can I convert it to float? I have tried tonumber() command but it doesn't work.
local airvolume = 10
if((time.min % 1)==0)then --Run every 5 minutes
   var1 = otherdevices['Heatpump Fan Speed']
   if var1 == 0 or var1 == 1 then
   airvolume = 0
   if var1 == 2 then
   airvolume = 120
   if var1 == 3 then
   airvolume = 220
   if var1 == 4 then
   airvolume = 320
   if var1 == 5 then
   airvolume = 520
   if var1 == 6 then
   airvolume = 620
   print( " ####Fan read: "..var1)
   print( " ####Airvolume: "..airvolume)
   OutletTemp = otherdevices_svalues['Heatpump Outlet Temp']
   InletTemp = otherdevices_svalues['Heatpump Inlet Temp']
   inpower = tonumber(otherdevices_svalues['Heatpump Power/Energy'])
   print( " ####Outlet temp: "..OutletTemp)
   print( " ####Inlet temp: "..InletTemp)
   print( " ####Power: "..inpower)
   outpower = 300*1.293*1.01*(OutletTemp-InletTemp)
   print( " ####Outpower: "..outpower)
Posted: Wednesday 17 October 2018 10:34
by juuzo
Ok Now I got it work. Required some try and error methods. Here's the working script with some other additions.
local debug = "1" -- Debug on = 1, off = 0
if((time.min % 2)==0)then --Run every 2 minutes
	if otherdevices['Heatpump Mode'] == "Heat" then
		inpower, energy = otherdevices_svalues['Heatpump Power/Energy']:match("([^;]+)")
			if var1 == "Auto" then
				airvolume = 0  --If fan is in Auto mode, air flow could not be determined
			elseif var1 == "1" then
				airvolume = 406.80  --Fan speed 1 means 406.80m3/h air flow
			elseif var1 == "2" then
				airvolume = 475.80  --Fan speed 1 means 475.80m3/h air flow
			elseif var1 == "3" then
				airvolume = 684.60  --Fan speed 1 means 684.60m3/h air flow
			elseif var1 == "4" then
				airvolume = 900.00  --Fan speed 1 means 900.00m3/h air flow
			elseif var1 == "5" then
				airvolume = 954.60  --Fan speed 1 means 954.60m3/h air flow
				print("####Ivalid FAN Speed") --If fan speed could not be read it is invalid and program terminated
				return
		inpowercompare = tonumber(string.format("%." .. (2) .. "f", inpower))
		if inpowercompare > 165 then --Panasonic minimum input power in Heat mode
			outpower = (OutletTemp-InletTemp)*airvolume*0.94*1.293*1.01--Assume that there is 6% error in air volume(0.96), 1.293 constant air density, 1.01 specific heat capacity for air
			outpowercompare = tonumber(string.format("%." .. (2) .. "f", outpower))
			if outpower > 0 then
				rawcop = outpower/(inpower/1000*3600) --inpower*3600, power consumption in hour
				cop = tonumber(string.format("%." .. (2) .. "f", rawcop))
				print( "####Outpower negative, Heapump de-ice?...")
				return
			print( "####Inpower too low, Heapump COP calculation not updated...")
			return
		if (debug == "1") then
			print( " ####Raw Cop calculation: "..rawcop)
			print( " ####Cop: "..cop)
		if cop < 12 then
			if cop > -0.01 then
				commandArray['UpdateDevice'] = COPidx..'|0|'..cop
				print( "####Heatpump COP updated")
				print ( "####COP too low, Heapump COP calculation not updated...")
			print( "####COP too high, Heapump COP calculation not updated...")
		print( "####Heatpump not in Heat mode...")
Posted: Friday 19 October 2018 10:46
by juuzo
I tested this scrip yesterday and noticed that I need some kind of averaging for this script. Have to resolve that next.
Posted: Tuesday 11 December 2018 19:27
by Derik
Dear...
Can you please tell me what airflow meter you have?
A china one?
What hardware do you use?
And where is the place you put the flowmeter?
