ELSEIF thermostat not triggering
Posted: Sunday 14 October 2018 18:30
by EdddieN
Hello
I have an Evohome zone and some Z-Wave thermostats. This kind of works ok, but only the first IF, not the second. What I'm doing wrong?
Basically I can override the temperature from either the Evohome or the Z-wave virtual thermostat. When I override from Evohome it works, but when I override from the virtual thermostant, only the Evohome part triggers.
Heating override
	on = { devices = { 'Downstairs', 'Downstairs Thermostat'} },    -- EvoHome trigger or Virtual Thermostat
	execute = function(domoticz, Thermostat)
	   local DownEV = Thermostat.setPoint -- Evohome zone Thermostat
	   local oldTemp = domoticz.variables('recordTempDown').value -- user variable to record last set temperature
	   local DownTRV = Thermostat.setPoint -- setpoint of Virtual thermostant
	   if DownEV ~= oldTemp and domoticz.variables('updateBusy').value == 0 then
	            domoticz.variables('updateBusy').set(1) -- I'm busy
                domoticz.devices('Downstairs Thermostat').updateSetPoint(DownEV)
                domoticz.variables('recordTempDown').set(DownEV)
                print ("***************** Virtual Thermostat Down UPDATED!! to: " ..DownEV.." ********************")
                domoticz.variables('updateBusy').set(0) -- Not busy anymmore
        elseif
                DownTRV ~= oldTemp and domoticz.variables('updateBusy').value == 0 then
                domoticz.variables('updateBusy').set(1) -- Set to busy
                local myZone = domoticz.devices('Downstairs') -- Evohome zone
                local untilDateTime = os.date("!%Y-%m-%dT%TZ",os.time()+7200)  -- current time + 2 hours
                myZone.updateSetPoint(DownTRV,"TemporaryOverride",untilDateTime)
		        domoticz.variables('recordTempDown').set(DownTRV)
		        print ("************ SETPOINT Evohome zone updated " .. myZone.name .. " to: " .. DownTRV .. " , until: " .. untilDateTime .. " *******")
                domoticz.variables('updateBusy').set(0) -- Not busy anymore
Re: ELSEIF thermostat not triggering
Posted: Sunday 14 October 2018 19:21
by waaren
EdddieN wrote: Sunday 14 October 2018 18:30 I have an Evohome zone and some Z-Wave thermostats. This kind of works ok, but only the first IF, not the second. What I'm doing wrong?
I think you got your logic wrong here.
The script is triggered by either the evoHome or the virtual sensor and you evaluate the setpoint of whichever triggered the script. Lua doe not know from which sensor you are getting it because you don't give that information. Result is that either the first if evaluates to true and that block will be executed so no evaluation of the 2nd (else) if will take place. Or the first if evaluates to false and because they are effectively looking at the same the 2nd (else)if is also false.
Also your busy variable is not of any use here. The domoticz event system is single threaded meaning that only one script can be executed at the same time so no chance of interference from another sensor. The 2nd script just have to wait until the 1st finished.
If have not tested the script but can you give it a try ?
Heating override
local EvoHome           =  'Downstairs'
local virtualThermostat = 'Downstairs Thermostat'
    on = { devices = { EvoHome, virtualThermostat }},    -- EvoHome trigger or Virtual Thermostat
       logging =   {   level   =   domoticz.LOG_DEBUG,
                        marker  =   "Heating override" },
       local downThermostat = Thermostat.setPoint                       -- Evohome or Virtual Thermostat.setPoint
       local trigger        = Thermostat.name
       if DownEV ~= oldTemp and Thermostat.trigger ==  virtualThermostat then
                -- domoticz.variables('updateBusy').set(1)                             -- I'm busy   This does not make sense. The update will only take place after the script has finished
        -- And there can only be one script active at the same time
                domoticz.devices(virtualThermostat).updateSetPoint(downThermostat)
                domoticz.variables('recordTempDown').set(downThermostat)
                print ("***************** Virtual Thermostat Down UPDATED!! to: " .. downThermostat .." ********************")
                -- domoticz.variables('updateBusy').set(0) -- Not busy anymmore This does not make sense. The update will only take place after the script has finished
        elseif
                downThermostat ~= oldTemp and Thermostat.trigger == EvoHome then
                -- domoticz.variables('updateBusy').set(1) -- Set to busy This does not make sense. The update will only take place after the script has finished
                myZone.updateSetPoint(downThermostat,"TemporaryOverride",untilDateTime)
                print ("************ SETPOINT Evohome zone updated " .. myZone.name .. " to: " .. downThermostat .. " , until: " .. untilDateTime .. " *******")
                -- domoticz.variables('updateBusy').set(0) -- Not busy anymore This does not make sense. The update will only take place after the script has finished
Posted: Sunday 14 October 2018 19:48
by EdddieN
Ok I get what you are doing now.
One thing missing is reading the value of the thermostat. How do you read the value of Evohome and virtualThermostate setpoint?
I try this but gives me a invalid parsing nil error:
Heating override
       local DownEV = Evohome.Thermostat.setPoint
       local downThermostat = virtualThermostat.Thermostat.setPoint
        elseif
Posted: Sunday 14 October 2018 20:14
by waaren
EdddieN wrote: Sunday 14 October 2018 19:48 Ok I get what you are doing now.
This line reads the setPoint from the device that triggered the script.
Can you show the relevant loglines ?
Posted: Sunday 14 October 2018 20:23
by EdddieN
waaren wrote: Sunday 14 October 2018 20:14
I need to read the setpoint of both, the ortherwise there's no way to compare the old value. The log is fine, it does not return errors. What happens is that the temperature does not transfer across neither the recordTempDown
The problem is here:
        elseif
DownEV and downThermostat have not been declared?
Posted: Sunday 14 October 2018 20:34
by EdddieN
Ok, I think I narrowed it down to this part of the code that is not triggering:
I have put debug info and I can see that trigger = Downstairs Thermostat but when comparing to the virtualThermostat = 'Downstairs Thermostat' it sees them as not equal. Any idea why?
Re: ELSEIF thermostat not triggering  [Solved]
Posted: Sunday 14 October 2018 20:41
by EdddieN
Finally, it works by replacing Thermostat.trigger with just trigger
Heating override
      -- print ("oldtemp " .. oldTemp)
      -- print ("Trigger " .. trigger)
      -- print ("Setpoint " .. downThermostat)
       if downThermostat ~= oldTemp and trigger ==  EvoHome then
        elseif
                downThermostat ~= oldTemp and trigger == virtualThermostat then
Thank you!
Posted: Monday 15 October 2018 21:07
by EdddieN
One final thing, I hope there's a solution for this.
My setup is as follows: I have the Evohome interface and then a wall mounted tablet with Imperihome. The thermostat in Imperihome changes by 0.5*C each touch so if I'm at 15 and I want to increase to 20*C, Imperihome sends 10 messages to Domoticz.
Then Domoticz as a good tasker starts to increase to 15.5 but before is finished it gets a new one and starts to get in a very long infinite loop of changes with the temperature UP and DOWN. I actually think that part of the culpit is Evohome being a bit slow to respond.
Is there any way to "buffer" or wait for the last command within the last 5 seconds to execute?
