Adding temperature sensor to Weather
Posted: Friday 12 October 2018 13:38
by jehali
Is it possible to add my temphumidity sensor to Weather?
Or is that not the option?
Re: Adding temperature sensor to Weather
Posted: Saturday 13 October 2018 13:38
by rv24531
Maybe, depends. Can you give us some insight to which temp/humidity sensor you have? If it's doable, someone here should be able to help, or at least point you in the right direction.
Posted: Saturday 13 October 2018 14:31
by jehali
I mean, it is now stored in the Temperature map but I want to move it to the Weather map.
In the Devices map it shows up like this:
349 RFLink 0008 0 BL999a Temp + Humidity WTGR800 25.5 C, 28 % - 100
Another problem is that is shows the humidity in %, but it counts the rainfall, so that has to be in mm/hr
