dasticz show several errors
Posted: Saturday 06 October 2018 22:54
by retetiba
I hope someone can help me with a couple of issues...
1. Dashticz remains showing domoticz path errors.
In my CONFIG.js I have the following text:
config['domoticz_ip'] = '
http://192.168.1.xxx:8080';
config['user_name'] = 'retetiba';
config['pass_word'] = 'yyy';
I checked these settings several times with the real domoticz path... and I can not find the error.
Swithes do work after loading the page... for some time, after that it says that it has a connection error. Only reloading the page solves the issue.
2. Is it correct that dashticz can only show items which are in the "dashboard" tab of domoticz?
regards
Rene
Re: dasticz show several errors
Posted: Sunday 07 October 2018 1:08
by HansieNL
What's the full Dashticz path? Did you install in Domoticz subfolder or are you running an other webserver?
Posted: Sunday 07 October 2018 21:33
by retetiba
I have installed dashticz in the standard folder (I think). The files are located in ~/domoticz/www/dashticz_v2.
I assume this is correct.
Posted: Monday 08 October 2018 12:00
by ArthurNL
retetiba wrote: Sunday 07 October 2018 21:33
So you access Dashticz by:
http://192.168.1.xxx:8080/dasticz_v2/index.html
Also attach your CONFIG.js and a screenshot of the actual error messages.
Posted: Wednesday 10 October 2018 19:26
by retetiba
Thank you for the reply. I have attached my config.js.
The error starts at the moment that dashtics is loading. with the "moving moons"loading it already states there is an error of my config.js and refers to wiki.
the dash starts normally, but after some (??) time it stops responding.
Hope anyone can help.
R
Posted: Wednesday 10 October 2018 20:59
by Lokonli
If you press F12 (in Chrome) look for errors in the console view. That might give an indication of the source of the problems.
Probably it's best to test it step by step: Test without the buttons and frames. They might give issues, especially when refreshing.
Posted: Wednesday 10 October 2018 22:15
by retetiba
thank you.
When doing this, I get the following errors in console:
Fout bij brontoewijzing: request failed with status 404
Bron-URL:
http://192.168.1.190:8080/dashticz_v2/vendor/head.js
Brontoewijzings-URL: head.load.min.js.map[Meer info]
Synchrone XMLHttpRequest op de hoofdthread wordt niet meer ondersteund vanwege de nadelige effecten op de eindgebruikerservaring. Zie
http://xhr.spec.whatwg.org/ voor meer informatie jquery.min.js:4:15141
Fout bij brontoewijzing: TypeError: NetworkError when attempting to fetch resource.
I am not an expert enough to understand.... anyone?
Posted: Thursday 11 October 2018 7:51
by Lokonli
You can ignore the XMLHttpRequest error. It should be a warning by the way.
The first error is a problem. The last sentence as well.
Try to find out which call is causing this. If you click on [Meer info] you probably will get more info.
If you reload dashticz and you look in the 'network' tab of the Chrome Developer Window (the one that appeared after pressing F12) you see all the resources that are being loaded. Can you make a screendump and post is here?
Posted: Friday 12 October 2018 21:30
by retetiba
I use firefox, so checking was a little different.
I found 3 items:
1. Error in de link of weather. Buienradar was ok, but the deeper link appeared to have an error --> fixed.
2. missing link on:
3.Fout bij brontoewijzing: TypeError: NetworkError when attempting to fetch resource.
Bron-URL: null
Brontoewijzings-URL: maps/swiper.min.js.map
Hope this gives more info.
Posted: Saturday 13 October 2018 10:12
by Lokonli
Probably it's best to start with a completely fresh install of dashticz (preferably latest beta), and then start adding screens and blocks to your config.js to see what introduces the error.
Posted: Friday 19 October 2018 19:06
by DarkG
I got the same Problem with a fresh install. By the way, settings get not stored else.
edit: Changed the IP directly in CONFIG.js
But on webserver the config will not stored. What can it be?
edit2: its because I use the Domoticz Webserver. I need a Webserver with PHP to save.
