Evohome: using a dummy switch to control thermostat
Posted: Thursday 04 October 2018 15:55
I have a Honeywell Round Connected thermostat, which can be controlled via EvoHome (mytotalconnectcomfort.com). I've installed the Honeywell EvoHome hardware in Domoticz, using the Web API-option. This works, and a Temperature device is created which shows the current room temperature and the setpoint.
However, for usability reasons (and WAF) I want a dummy switch so I can manually control the thermostat setpoint from the Android app.
I've created a dummy switch, and use the following script:
Running the script shows no errors, and indeed, the setpoint of the thermostat device is changed to the set value of the dummy switch. However, within a minute this value is overwritten by the previous value.
I'm not even sure if the actual setpoint is changed on the thermostat itself, or if it's only in Domoticz where it's changed. It looks like the set values by the script are overwritten by the values from the Honeywell-servers.
How can I resolve this in a proper way?
#!/bin/bash
#### Description of get_watermeter.sh
#### Purpose: To read and write Current Living Temp and Thermostat Setpoint from/into Domoticz
#### Created: 2016-11-05
#### Modified: 2016-11-07
#### Owner: STLAHA2007
#### Functionalities: Read current temp and setpoint from Domoticz {curl/json/grep/awk/sed}
#### Write into combined Zone sensor to Domoticz {curl/json/grep/awk/sed}
#### This script needs {Unix-style} execute rights (755 - rwx r-x r-x)
#### Declare temporary variables for read/calculate/write
declare CurrentLiving_Temp
declare CurrentLiving_SetPoint
declare -i CurrentLiving_Temp_IDX
declare -i CurrentLiving_SetPoint_IDX
declare HeatZoneLiving_Value
declare -i HeatZoneLiving_IDX
declare DomoURL
DomoURL=$(echo "http://127.0.0.1:8080")
CurrentLiving_Temp_IDX=658 ### Temperature Sensor (Temperature Tab)
CurrentLiving_SetPoint_IDX=657 ### SetPoint Device (Utility Tab)
HeatZoneLiving_IDX=658 ### Your Zone Device (Temperature Tab) or modify url below the rebuild for the switch!!!!
#### read and calculate current temp and setpoint
CurrentLiving_Temp=$(echo $(curl -s "$(echo $DomoURL)/json.htm?type=devices&rid=$(echo $CurrentLiving_Temp_IDX)" | grep "Data\"" | awk '{print $3}' | sed 's/\"//g' | sed 's/\,//g'| sed 's/\.000//g' ))
CurrentLiving_SetPoint=$(echo $(curl -s "$(echo $DomoURL)/json.htm?type=devices&rid=$(echo $CurrentLiving_SetPoint_IDX)" | grep "Data\"" | awk '{print $3}' | sed 's/\"//g' | sed 's/\,//g'| sed 's/\.000//g' ))
HeatZoneLiving_Value=$(echo $(curl -s "$(echo $DomoURL)/json.htm?type=devices&rid=$(echo $HeatZoneLiving_IDX)" | grep "Data\"" ))
echo $HeatZoneLiving_Value
echo "HeatzoneLiving_Value needs to look like....:"
HeatZoneLiving_Value=$(echo $CurrentLiving_Temp";"$CurrentLiving_SetPoint";0;")
##echo "Electra: "$(echo $M_E_Curr)" kWh Gas: "$(echo $M_G_Curr)" m3 Water: "$(echo $M_W_Curr)" m3"
curl -s "$(echo $DomoURL)/json.htm?type=command¶m=udevice&idx=$(echo $HeatZoneLiving_IDX)&nvalue=0&svalue=$(echo $HeatZoneLiving_Value)"Code: Select all
pi@raspberrypi:~/domoticz/scripts $ ./set_temp.sh
22.5
19.5
"Data" : "22.5 C, (22.0 C), TemporaryOverride until 2018-10-04T22:00:00Z",
22.5;19.5;0;
"status" : "OK",
"title" : "Update Device"
