bathroom hum script
Posted: Sunday 30 September 2018 19:22
by pro2call
I’m Looking to build a script to manage my humidity in the bathroom.
My current setup in parts:
1x KAKU wall switch
1x KAKU 0-10v dimmer
1x cresta temp & hum sensor
1x Stork air CMFE
1x Opentherm converter
Wishes of the script:
When hot tap water is heating for 5 minutes then the KAKU Wall switch must be turned on. If it doesn’t reach 5 minutes than it must do nothing.
When hot tap water is turned off it must going to read the humidity of the Cresta temp sensor and with that value it has to control the speed of the CMFE with 0-10v. after 90 minutes it has to turn of the CMFE with the following procedure: first set 0-10 dimmer to off then let he motor spin to a halt and then turn off the wall switch.
Of course the procedure must as a feature that in the 90 minutes of run time the hot water is enabled again the procedure starts again.
Hum - Speed
Higher then 70 speed is 50
Equal to 70 speed is 45
Equal to 69 speed is 40
Equal to 68 speed is 35
Equal to 67 speed is 30
Equal to 66 speed is 25
Equal or below 65 speed is 0 and device is turned off.
Please help
