Camera domoticz
nickos
Camera domoticz
Post by nickos »
Hello
Is it possible to display the camera in the dashboard domoticz.
If so how.
thank you
Rpi + RFXcom USB + Domoticz
mbliek
Re: Camera domoticz
Post by mbliek »
This is not possible. Only by modifying the original html page
nickos
Re: Camera domoticz
Post by nickos »
and someone would have already done it?
gizmocuz
Re: Camera domoticz
Post by gizmocuz »
if you associate devices with the camera (for instance a dummy switch) on the dashboard you will see a camera icon on that switch.
clicking this will show the live camera.
maybe this works for the time being...
nickos
Re: Camera domoticz
Post by nickos »
hello
is it possible to have a bit more explanation?
Mince Inside
Re: Camera domoticz
Post by Mince Inside »
Is there any more info on dummy switches and associating a camera as I like the idea but not having much success?
TIA M
Domoticz V2.2259
Raspberry Pi (B) with PiFace
RFXtrx433 USB
LighwaveRF relays, dimmer bulbs and light switches
Siemens On/Off 13A adaptors
Marmitek MS13E Motion (and Dusk) sensors
anthropo
Re: Camera domoticz
Post by anthropo »
Create a Dummy switch
Set your camera and in the bottom add this switch as a device
the you are done.
spudgunman
Re: Camera domoticz
Post by spudgunman »
what device did you use to get that nice camera icon graphic?
=update found this am reading up on http://www.domoticz.com/wiki/Custom_ico ... binterface
I can be ok with this method but ideally I would like a virtual sensor type of Camera where I could just do this professionally. I tried using a text virtual sensor which is a utility type (nice) but I cant attach a camera to a text virtual sensor (bug?)
spudgunman
Re: Camera domoticz
Found a better way to do this.
using a Ping Hardware switch (pinging my camera IP) then attaching the camera to the new Ping/Switch
this will show real status that the camera is online and viewable.. I love it.
Evelen
Domoticz version: 2.4538
Re: Camera domoticz
Post by Evelen »
spudgunman wrote:Found a better way to do this.
How? :P
elgarne
Re: Camera domoticz
Post by elgarne »
Thanks all of you for this hint, especially anthropo.
Evelen
Re: Camera domoticz
Post by Evelen »
ok, what now?
Uten navn.png (298.98 KiB) Viewed 6928 times
