Fibaro wall plug ring colours
Posted: Wednesday 26 September 2018 17:28
by mcmikev
I am trying to get a fibaro wall plug to change the ring colour when a device or state is on or changed.
I know the code for colour red and off, from another post but how do I get the other codes for green etc?
Anyone knows these codes and want to share them so we can change the ring colour ?
To change the ring to red:
http://127.0.0.1:8080/json.htm?type=command&param=applyzwavenodeconfig&idx=75&valuelist=42_UmVkIGlsbHVtaW5hdGlvbg%3D%3D_
To turn off
http://127.0.0.1:8080/json.htm?type=command&param=applyzwavenodeconfig&idx=75&valuelist=42_aWxsdW1pbmF0aW9uIHR1cm5lZCBvZmYgY29tcGxldGVseQ%3D%3D_
Where the IDX number is the one you get from reading the zwave controller so that is per user different.
Hope someone knows these codes :-)
Re: Fibaro wall plug ring colours
Posted: Monday 25 February 2019 16:34
by frustreerMeneer
Maybe you found out in the meantime but it is described here:
https://www.domoticz.com/wiki/Domoticz_ ... ve_devices
Look at the section 'Changing a zwave device parameter'.
Posted: Monday 25 February 2019 17:16
by mcmikev
Did some searching and testing. Was a finding game for me :-)
But did the trick eventually.
This are the codes for the colours
Red
Magenta
_TWFnZW50YSBpbGx1bWluYXRpb24%3D_
White
_V2hpdGUgaWxsdW1pbmF0aW9u_
Green
_R3JlZW4gaWxsdW1pbmF0aW9u_
Blue
_Qmx1ZSBpbGx1bWluYXRpb24%3D_
Yellow
_WWVsbG93IGlsbHVtaW5hdGlvbg%3D%3D_
Cyan
_Q3lhbiBpbGx1bWluYXRpb24%3D_
Off
These codes come behind the &valuelist=42 directly.
So for example tunring the ring on as status in colour blue would be
http://127.0.0.1:8080/json.htm?type=command&param=applyzwavenodeconfig&idx=75&valuelist=42_Qmx1ZSBpbGx1bWluYXRpb24%3D_
Posted: Monday 25 February 2019 17:29
by frustreerMeneer
Ok, great! Will try them when i get my plugs :-)
Posted: Thursday 24 November 2022 11:25
by Kochmeister
I found this topic as I was looking for the ring color change in on / off state of the FGWPE/F Wall Plug Gen5+.
I run domoticz on the raspberry pi, and I can change color settings in the Z-wave stick controller.
However the plug does not apply these settings.
When using the commands above the setting will change accordingly, however not at the plug itself.
I only can see the ring flash white when the on/off status changes.
can someone point me in the correct direction? or does this simply not work anymore from domoticz?
Posted: Friday 25 November 2022 20:05
by Gravityz
i do this from a linux script
if i remember correctly you can change the color for both the ON state as well as the off state.
maybe this will help you out. change ip address to the one you need
if you only want to change the color once(eg green on, no light off) this will work as well
for normal operation
off= no color
on=green
for setting alarm state
off=red
on=red
normal state script
normal.sh
#!/bin/bash
curl -s "http://192.168.1.50:8084/json.htm?type=command&param=applyzwavenodeconfig&idx=5&valuelist=41_R3JlZW4gaWxsdW1pbmF0aW9u_42_aWxsdW1pbmF0aW9uIHR1cm5lZCBvZmYgY29tcGxldGVseQ%3D%3D_"
curl -s "http://192.168.1.50:8084/json.htm?type=command&param=applyzwavenodeconfig&idx=6&valuelist=41_R3JlZW4gaWxsdW1pbmF0aW9u_42_aWxsdW1pbmF0aW9uIHR1cm5lZCBvZmYgY29tcGxldGVseQ%3D%3D_"
curl -s "http://192.168.1.50:8084/json.htm?type=command&param=applyzwavenodeconfig&idx=7&valuelist=41_R3JlZW4gaWxsdW1pbmF0aW9u_42_aWxsdW1pbmF0aW9uIHR1cm5lZCBvZmYgY29tcGxldGVseQ%3D%3D_"
alarm state script
alarm.sh
#!/bin/bash
curl -s "http://192.168.1.50:8084/json.htm?type=command&param=applyzwavenodeconfig&idx=5&valuelist=41_UmVkIGlsbHVtaW5hdGlvbg%3D%3D_42_UmVkIGlsbHVtaW5hdGlvbg%3D%3D_"
curl -s "http://192.168.1.50:8084/json.htm?type=command&param=applyzwavenodeconfig&idx=6&valuelist=41_UmVkIGlsbHVtaW5hdGlvbg%3D%3D_42_UmVkIGlsbHVtaW5hdGlvbg%3D%3D_"
curl -s "http://192.168.1.50:8084/json.htm?type=command&param=applyzwavenodeconfig&idx=7&valuelist=41_UmVkIGlsbHVtaW5hdGlvbg%3D%3D_42_UmVkIGlsbHVtaW5hdGlvbg%3D%3D_"
Posted: Thursday 01 December 2022 13:37
by Kochmeister
Thanks for this.
For me it does not seem to work. I think this is because I have an older gen-5 Zwave stick.
Als the plug shows up as "wall plug gen5+" I assume for this to work I need a gen5+ Zwave stick. (normal on/off switching does work!)
So i think I need to accept that I cannot change the color, or need to upgrade the stick.
Posted: Wednesday 07 December 2022 18:44
by Gravityz
can you change the colors from the device settings in domoticz
