[SOLVED] Is it possible to use Dzvents without setting 127.0.0.1 in local networks, or use another IP?
Posted: Tuesday 25 September 2018 14:10
by stewdyne
I use Dataplicity.com to access my rpi externally. By using this service you get a url (a so called dataplicity wormhole).
If I put in 127.0.0.1 in my local networks in the Domoticz settings, anybody can directly access my rpi/domoticz if they know the dataplicity wormhole url. No username/password is required since 127.0.0.1 is allowed.
Re: Is it possible to use Dzvents without setting 127.0.0.1 in local networks, or use another IP?
Posted: Tuesday 25 September 2018 16:50
by waaren
stewdyne wrote: Tuesday 25 September 2018 14:10
If you remove 127.0.0.1 some of the dzVents commands (RGBW device and opentherm related) and all scripts containing domoticz.settings['Domoticz url'] will fail.
If it helps you...
if you replace 127.0.0.1 by the actual IP address of your PI and change the string "127.0.0.1" in dzVents/runtime/EventHelpers.lua to this IP address these commands and scripts will still work.
I am not sure that this answer covers the whole story; but this is what I experienced.
Note that the EventHelpers.lua will be overwritten on every domoticz update.
Re: [SOLVED] Is it possible to use Dzvents without setting 127.0.0.1 in local networks, or use another IP?
Posted: Wednesday 26 September 2018 7:39
by stewdyne
Thank you Waaren! This solved the problem for me.
