How to get the time a switch is activated in log/notification
Posted: Monday 24 September 2018 23:08
I am trying to get the time a switch is turned on into the log. Tried it like this:
But this is not giving the time the switch was switched ON but the last time it was switched OFF.
You can see it in the log:
So:
Switch ON at: 23:03:23
In the log: 22:48:13
Switch OFF at: 23:04:07
In the log: 23:03:23
It must be like this:
In the log: 23:04:07
Can somebody help me with this?
devices = {
'Keypad Access Control'
if (device.state == 'On') then
domoticz.log('Device ' .. device.name .. ' is ingeschakeld om: ' .. device.lastUpdate.raw .. '', domoticz.LOG_INFO)
domoticz.log('Device ' .. device.name .. ' is uitgeschakeld om: ' .. device.lastUpdate.raw .. '', domoticz.LOG_INFO)
2018-09-24 23:03:23.723 Status: User: Admin initiated a switch command (21/Keypad Access Control/On)
2018-09-24 23:03:23.838 Status: dzVents: Info: Handling events for: "Keypad Access Control", value: "On"
2018-09-24 23:03:23.839 Status: dzVents: Info: ------ Start internal script: myAlarm_keypad: Device: "Keypad Access Control (ideAlarm)", Index: 21
2018-09-24 23:03:23.839 Status: dzVents: Info: Device Keypad Access Control is ingeschakeld om: 2018-09-24 22:48:13
2018-09-24 23:03:23.839 Status: dzVents: Info: ------ Finished myAlarm_keypad
2018-09-24 23:04:06.894 Status: User: Admin initiated a switch command (21/Keypad Access Control/Off)
2018-09-24 23:04:07.009 Status: dzVents: Info: Handling events for: "Keypad Access Control", value: "Off"
2018-09-24 23:04:07.009 Status: dzVents: Info: ------ Start internal script: myAlarm_keypad: Device: "Keypad Access Control (ideAlarm)", Index: 21
2018-09-24 23:04:07.009 Status: dzVents: Info: Device Keypad Access Control is uitgeschakeld om: 2018-09-24 23:03:23
2018-09-24 23:04:07.010 Status: dzVents: Info: ------ Finished myAlarm_keypadSwitch ON at: 23:03:23
