Page 1 of 18
Python Plugin: Zigbee2Mqtt
Posted: Friday 21 September 2018 18:04
by StasDemydiuk
zigbee2mqtt project allows you to use your Zigbee devices without the vendors (Xiaomi/TRADFRI/Hue) bridge or gateway.
It bridges events and allows you to control your Zigbee devices via MQTT.
This plugin adds zigbee2mqtt support into domoticz
https://github.com/stas-demydiuk/domoti ... qtt-plugin
Plugin subscribes to mqtt messages from zigbee2mqtt app and creates devices in domoticz once receive any message from them.
For battery powered devices it also handles battery level if it is available in the message
Currently supported device list and instructions for installation you can find in plugin repository.
If you find any issues please report them directly in github. Any contributions are welcome.
02.05.2020 Update:
New version of plugin (v.0.2.0) has been released which among other changes introduces additional page to Domoticz UI to manage the plugin and zigbee2mqtt instance:
Any feedback is highly welcome.
Re: Python Plugin: Zigbee2Mqtt
Posted: Friday 28 September 2018 20:30
by tezzlicious
Just had time to dive into this. Looking very nice. Got all necessary parts up and running. Just need support for the Aqara door/window sensor.
Thanks for all the efforts.
Edit: Stanislav added support for the Aqara door/window sensor as we speak.
Posted: Friday 28 September 2018 23:23
by jake
Did you check out
this topic already? It is about the same project.
Posted: Monday 01 October 2018 9:15
by MiloshCZ
jake: This thread is about new plugin, that supports Zigbee2MQTT. I think, that plugin is better than NOdeRed implementation.
StasDemydiuk: Nice work, please continue with it.
Posted: Monday 01 October 2018 12:16
by MarFan
I'm trying to get this installed.
I followed your instruction on Github, but see that the important flag "include_device_information" is in the DEV verion of Zigbee2MQTT.
How to get this version ?
Posted: Monday 01 October 2018 15:14
by StasDemydiuk
MarFan wrote: Monday 01 October 2018 12:16
It depends on how are you running zigbee2mqtt:
if you just downloaded it by cloning git repository, then checkout dev branch
if you are using docker container, it has special tag with build from dev branch
Posted: Monday 01 October 2018 16:08
by MarFan
StasDemydiuk wrote: Monday 01 October 2018 15:14
Thanks, it's working.
a) what means the log-Message
"Device Z2M - Cube does not have saved model" I also see this by my xiaomi double button.
b) is there also a option to send set messages (to contol a IKEA lamp ?)
c) I created sensor_86sw1 (Xiaomi WXKG03LM). How do you want to add this ?
Posted: Tuesday 02 October 2018 8:18
by StasDemydiuk
what means the log-Message "Device Z2M - Cube does not have saved model"
It means that currently this plugin doesn't support this device.
Yes zigbee2mqtt has ability to control devices and this this plugin also supports this ability when applicable
If device is not supported yet, you probably can create issue on github to add support for specific device and attach examples of mqtt messages from device and commands to control it if applicable as unfortunately I don't have all these devices.
Posted: Tuesday 02 October 2018 15:21
by MarFan
StasDemydiuk wrote: Tuesday 02 October 2018 8:18
This is strange, as test I used the Cube and the double switch. Both are created by the plugin and work.
In the code I see the implementation of these Xiaomi devices?
Oké, I will create sample of mqtt message for the devices.
Oké, clear. I already added the single switch in code, but will create a issue in GitHub.
I created the SW1 with the code of SW2, but did not find the option to create it as a push-button type instead of selection
Posted: Tuesday 02 October 2018 22:38
by StasDemydiuk
Sorry, misunderstood your first message, yes, you're right, cube is supported by plugin.
I wonder if you could follow these steps to find root cause of your issue:
1. delete your cube device created by plugin from domoticz
2. make any action with cube to force plugin to recreate it
3. check if everything is working fine
4. repeat all changes that you've done with cube and try to identify after what change it stops working
Posted: Wednesday 03 October 2018 7:50
by StasDemydiuk
Could you please provide example of MQTT message for this device and I'll add support
Posted: Wednesday 03 October 2018 21:26
by upwindanderl
@StasDemydiuk
YOU are my hero
I installed domoticz only because of your plugin.
I know it's the very first beginning of the plugin, but I think this is my perfect solution
I tried to install today and after the GitHub clone and the configuration.yaml thing I can't see the "type "Zigbee2MQTT"" in my hardware menu
Do you have any idea?
edit:
omg - i see, sometimes reading is helpful
i installed zigbee2mqtt M O N T H S ago and of course with the normal git clone
sudo git clone https://github.com/Koenkk/zigbee2mqtt.git /opt/zigbee2mqtt
two questions, how can I change to the dev branch?!
Is it only a reinstall or do I have to consider something that it doesn't end in a second install version?
Do i loose all my already linked zigbee devices ??
You see - I'm not used in ubuntu / terminal e.g. at all - but I managed a lot
Maybe you can help out
Posted: Thursday 04 October 2018 19:30
by StasDemydiuk
@upwindanderl that should help:
cd /opt/zigbee2mqtt
git fetch
git checkout dev
npm install
Posted: Friday 05 October 2018 10:18
by upwindanderl
StasDemydiuk wrote: Thursday 04 October 2018 19:30
cd /opt/zigbee2mqtt
git fetch
git checkout dev
npm install
THANKS !!!! But do you think i don't lose my already connected sensors and actors with this kind of install?!
Posted: Friday 05 October 2018 20:08
by StasDemydiuk
I would say no as they are paired to your controller, not to zigbee2mqtt, so most likely everything will be ok
Posted: Saturday 06 October 2018 16:12
by upwindanderl
puuuuuuuh long way
so i'm already on the dev branch
and i installed npm and after all i don't see any zigbee hardware:
So
I thought it could be a problem with a not updatet zigbee2mqtt
and i tried to update and while the npm install i get following errors
pi@raspberrypi:/opt/zigbee2mqtt2 $ sudo git checkout dev
M data/configuration.yaml
Already on 'dev'
Your branch is up-to-date with 'origin/dev'.
pi@raspberrypi:/opt/zigbee2mqtt2 $ sudo systemctl stop zigbee2mqtt
pi@raspberrypi:/opt/zigbee2mqtt2 $ cp -R data data-backup
pi@raspberrypi:/opt/zigbee2mqtt2 $ sudo git checkout HEAD -- npm-shrinkwrap.json
pi@raspberrypi:/opt/zigbee2mqtt2 $ sudo git pull
Already up-to-date.
pi@raspberrypi:/opt/zigbee2mqtt2 $ sudo rm -rf node_modules
pi@raspberrypi:/opt/zigbee2mqtt2 $ sudo npm install
Unhandled rejection Error: Command failed: /usr/bin/git clone --depth=1 -q -b master https://github.com/Koenkk/zigbee-shepherd.git /root/.npm/_cacache/tmp/git-clone-29bcec6d
/root/.npm/_cacache/tmp/git-clone-29bcec6d/.git: Permission denied
at ChildProcess.exithandler (child_process.js:275:12)
at emitTwo (events.js:126:13)
at ChildProcess.emit (events.js:214:7)
at maybeClose (internal/child_process.js:925:16)
at Socket.stream.socket.on (internal/child_process.js:346:11)
at emitOne (events.js:116:13)
at Socket.emit (events.js:211:7)
at Pipe._handle.close [as _onclose] (net.js:554:12)
Unhandled rejection Error: Command failed: /usr/bin/git clone --depth=1 -q -b master https://github.com/Koenkk/zcl-packet.git /root/.npm/_cacache/tmp/git-clone-a9db7c08
/root/.npm/_cacache/tmp/git-clone-a9db7c08/.git: Permission denied
at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
Unhandled rejection Error: Command failed: /usr/bin/git clone --depth=1 -q -b master https://github.com/Koenkk/cc-znp.git /root/.npm/_cacache/tmp/git-clone-ed91fbf9
/root/.npm/_cacache/tmp/git-clone-ed91fbf9/.git: Permission denied
> [email protected] install /opt/zigbee2mqtt2/node_modules/serialport
> prebuild-install || node-gyp rebuild
prebuild-install WARN install No prebuilt binaries found (target=8.9.4 runtime=node arch=arm platform=linux)
gyp ERR! configure error
gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/zigbee2mqtt2/node_modules/serialport/build'
gyp ERR! System Linux 4.14.52-v7+
gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /opt/zigbee2mqtt2/node_modules/serialport
gyp ERR! node -v v8.9.4
gyp ERR! node-gyp -v v3.8.0
gyp ERR! not ok
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! [email protected] install: `prebuild-install || node-gyp rebuild`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2018-10-06T14_10_33_245Z-debug.log
Maybe some idea anyone??!
Posted: Sunday 07 October 2018 9:57
by StasDemydiuk
Looks like some permissions issue, you could try to clone zigbee2mqtt into another folder just for test and copy your data/configuration.yml file to restore your configuration
Posted: Monday 08 October 2018 19:12
by MarFan
StasDemydiuk wrote: Tuesday 02 October 2018 22:38
Sorry for the delay, was very busy on other projects. Will do this tomorrow. Also will try to create mqtt samples for other devices.
I deleted the cube (and switch) and recreated them. Now the message is gone (
I first updated to the latest version).
Strange thing is, that for both devices Domoticz hangs when making an action for that device (to start the creation of the device) .
After a restart, the device is added and works perfect.
I can reproduce this behavior for these 2 devices. (I only have 1 to test, but I will receive one switch asap)
I do not see this behavior when I add a motion sensor or the door/window sensor ? (can delete and add them without any problems)
Anybody else saw this behavior ?
Posted: Wednesday 10 October 2018 9:12
by StasDemydiuk
I deleted the cube (and switch) and recreated them. Now the message is gone (I first updated to the latest version).
Looks like it is architectural issue as plugin stores additional zigbee related information inside device options which as it turned out is not allowed for devices with own options (Selector Switches)
viewtopic.php?f=65&t=25071. So it works only until you change level name or action inside selector switch.
I will try to make something up to avoid this restriction.
Posted: Sunday 14 October 2018 18:32
by upwindanderl
StasDemydiuk wrote: Sunday 07 October 2018 9:57
yeah it was... for every one else
Ultramizers 2nd Post was my clue
Anyway i'm not in the goal
Now i have the newest zigbee2mqtt and as well the dev branch installed.
I did the flag thing in the yaml
I cloned your plugin and restarted domoticz.
No Zigbee Hardware Device at all ... any debug ideas anyone??
