Question regarding dzvents triggers
dzdm
Post by dzdm »
I have some questions regarding dzvents triggers:
(TestDev is a Switch)
1. Will a on = { devices = { 'TestDev' } } be triggered when the device is on and a state change on->on occurs (yes, on to on)?
The background is, that I have a device which can be on or off. Additionally, it sends periodic status reports, so it is possible that there will be a on->on state change.
2. Does a domoticz switch item have a lastState flag?
3. changed: Boolean. True if the device was changed -> When exactly will this be set?
Thank you :)
SweetPants
Re: Question regarding dzvents triggers
Post by SweetPants »
dzdm wrote: Thursday 20 September 2018 14:42
As far as I know yes. I use a dummy switch for each phone detected and reset a lastupdate timer for each phone if it is (re)detected again.
dzdm wrote: Thursday 20 September 2018 14:42 I have some questions regarding dzvents triggers:
1. Yes (see test script below)
2. No. Previous states of switches are only kept in the history tables. dzVents can store it in persistent data (see test script below)
nb. a dimmer does store it's last dimlevel
3. Not sure what you mean here. Please elaborate a bit on the case where you want it for.
    on = { devices = { "TestDev"}}  ,
    data    =   { previousState = { initial = "initialized" } },
    execute = function(dz, item)
        dz.log(item.name .. " ==>  state:  " .. item.state .. "; previous state: " .. dz.data.previousState)
        dz.data.previousState = item.state
