Recently I had a lot of timeouts from my multisensory. Disabling polling was the solution. However, that meant my illumination values were not being updated.
I looked in the settings and here on the forum. Found a setting that works:
However, why do I need to fill in 255? Where can I find more information on what every setting means? What it does and what values to use?
At first I entered "7", because I read "7 -> Luminosity"
Settings Aeon multisensor Gen 5
mantoz
- Domoticz version: 2024.7
Re: Settings Aeon multisensor Gen 5
please note that the number is 225, not 255.
It is created depending on the indicated bits as below:
bit 0 -> battery report
bit 5 -> temperature
and so on.
So that settings all reports to active leads to:
1 (bit 0 set) + 32 (bit 5 set) + 64 (bit 6 set) + 128 (bit 7 set) = 225
Hope this helps!
mantoz
and so on.
Hope this helps!
mantoz
Plantje
Ah ok, like that. It sure helps! Thanks!
And 225 reports all? 97 would be everything up until humidity, 33 until temperature, 1 only battery and 0 nothing?
Where could I have read this?
mantoz
Yes, it should work that way.Plantje wrote: Wednesday 19 September 2018 22:01 Ah ok, like that. It sure helps! Thanks!
Don't know where you can find that info, probably somewhere in Z-Wave documentation, but I can't say where, sorry.
Maybe other users can help.
mantoz
