Darksky rain forecast
Posted: Monday 17 September 2018 13:30
This script requires prior registration to the DarkSky API
Enter the URL and request a free API key
https://darksky.net/dev
Add, modify or delete variables proba_pluie_h [] by changing the number (hour) between []
the name "in quotation marks" or the idx without quotes (avoid accents) of the device of percentage of rain at [x] associated time, nil if not used
This script can potentially retrieve the 48 available time forecasts. Create as many percent virtual sensors as you would expect from the hourly forecasts.
for my part, I only get the forecasts at 1 hour, 2 hours, 4 hours, 6 hours, 12 hours and 24 hours.
Only 48 possible forecasts
My DarkSky secret key, the latitude and longitude of my home are contained in 3 user variables
If you want to enter this information directly into the script, comment the two lines above, uncomment the following two lines by personalizing them with your personal data
finally, you can choose the level of logs, only one level can be active; comment on others in the section
local DarkSkyAPIkey = domoticz.variables('api_forecast_io').value
local geolocalisation = domoticz.variables('Latitude').value..","..domoticz.variables('Longitude').valueCode: Select all
--local DarkSkyAPIkey = "1a2bf34bf56c78901f2345f6d7890f12"
--local geolocalisation = "45.87,1.30" -- latitude,longitude Code: Select all
--[[ darksky.lua for [ dzVents >= 2.4.14 (domoticz >= V4.10444)]
author/auteur = papoo
update/mise à jour = 05/08/2019
creation = 15/09/2018
https://pon.fr/ddzvents-darksky-probabilite-de-vent-et-phases-lunaires/
https://github.com/papo-o/domoticz_scripts/blob/master/dzVents/scripts/darksky.lua
https://www.domoticz.com/forum/viewtopic.php?f=59&t=24928
https://easydomoticz.com/forum/viewtopic.php?f=17&t=7136&p=58822#p58822
Ce script nécessite l'inscription préalable à l'API DarkSky
Entrez l'URL et demandez une clé API gratuite
place this DZvents script in /domoticz/scripts/dzVents/scripts/ directory
script dzvents à placer dans le répertoire /domoticz/scripts/dzVents/scripts/
Ajoutez, modifiez ou supprimez les variables proba_pluie_h[] en changeant le nombre (heure) entre []
renseigner ensuite le nom "entre guillemets" ou l'idx sans guillemets (évitez les accents) du device pourcentage probabilité pluie à [x] heure associé, nil si non utilisé
Ce script peut potentiellement récupérer les 48 prévisions horaires disponible. Créez autant de capteurs virtuels pourcentage correspondant aux prévisions horaires que vous souhaitez.
pour ma part, je ne récupère que les prévisions à 1 heure, 2 heures, 4 heures, 6 heures, 12 heures et 24 heures.
Seulement 48 prévisions possible
My DarkSky secret key, the latitude and longitude of my home are contained in 3 user variables (type string)
Ma clé secrète DarkSky, la latitude et la longitude de mon domicile sont contenus dans 3 variables utilisateurs (type chaine)
If you want to enter this information directly into the script, comment the line above, uncomment the following line
Si vous souhaitez inscrire ces informations dans le script, commentez la ligne ci-dessus, décommentez la ligne suivante
--local DarkSkyAPIkey = "1a2bf34bf56c78901f2345f6d7890f12" --fake API number
by personalizing it with your personal data
en la personnalisant avec vos données personnelles.
enfin vous pouvez choisir le niveau de "verbiage" des logs, seulement un niveau peut être actif; commenter les autres dans la section logging
local scriptName = 'Darksky forecast'
local scriptVersion = ' 1.21'
local proba_pluie_h = {}
local prev_wind_h = {}
local MoonPhaseSelect = {}
proba_pluie_h[1] = 'Proba Pluie 1h'
proba_pluie_h[2] = 'Proba Pluie 2h'
proba_pluie_h[3] = nil
proba_pluie_h[4] = 'Proba Pluie 4h'
proba_pluie_h[5] = nil
proba_pluie_h[6] = 'Proba Pluie 6h'
proba_pluie_h[12] = 'Proba Pluie 12h'
proba_pluie_h[24] = 508
proba_pluie_h[36] = nil
proba_pluie_h[48] = nil
prev_wind_h[1] = 'Vent dans 1 heure'
prev_wind_h[2] = nil
prev_wind_h[3] = nil
prev_wind_h[4] = nil
prev_wind_h[5] = nil
prev_wind_h[6] = nil
prev_wind_h[12] = nil
prev_wind_h[24] = nil
prev_wind_h[36] = nil
prev_wind_h[48] = nil
MoonPhaseSelect[1] = 2479 --moonPhase day 1 selector switch
MoonPhaseSelect[2] = nil --moonPhase day 2 selector switch
MoonPhaseSelect[3] = nil --moonPhase day 3 selector switch
MoonPhaseSelect[4] = nil --moonPhase day 4 selector switch
MoonPhaseSelect[5] = nil --moonPhase day 5 selector switch
MoonPhaseSelect[6] = nil --moonPhase day 6 selector switch
MoonPhaseSelect[7] = nil --moonPhase day 7 selector switch
MoonPhaseSelect[8] = nil --moonPhase day 8 selector switch
active = true,
on = { timer = { 'every 30 minutes' }, -- remember only 1000 requests by day, 30mn = 48 requests
httpResponses = { 'DarkSky_Trigger' } -- Trigger the handle Json part
logging = { level = domoticz.LOG_DEBUG, -- Seulement un niveau peut être actif; commenter les autres
-- level = domoticz.LOG_INFO, -- Only one level can be active; comment others
-- level = domoticz.LOG_ERROR,
-- level = domoticz.LOG_MODULE_EXEC_INFO,
marker = scriptName..' v'..scriptVersion
data = { Forecast = {initial = {} }, -- Keep a copy of last json just in case
local function logWrite(str,level) -- Support function for shorthand debug log statements
domoticz.log(tostring(str),level or domoticz.LOG_DEBUG)
local function quadrants(degrees)
local quadrants = {"NNE","NE","ENE","E","ESE","SE","SSE","S","SSW","SW","WSW","W","WNW","NW","NNW"}
if degrees > 348.75 or degrees <= 11.25 then
return "N"
local index = tonumber(math.floor((degrees - 11.25) / 22.5)+1)
return quadrants[index]
local function levelMoonhase(moonphase)
local level = 10 -- level correspondant à Nouvelle lune
if(moonphase > 0.05 and moonphase < 0.245) then
level = 20 -- level correspondant à Premier croissant
elseif(moonphase > 0.244 and moonphase < 0.255) then
level = 30 -- level correspondant à Premier quartier
elseif(moonphase > 0.255 and moonphase < 0.495) then
level = 40 -- level correspondant à Gibbeuse croissante
elseif(moonphase > 0.495 and moonphase < 0.55) then
level = 50 -- level correspondant à Pleine lune
elseif(moonphase > 0.55 and moonphase < 0.745) then
level = 60 -- level correspondant à Gibbeuse décroissante
elseif(moonphase > 0.745 and moonphase < 0.755) then
level = 70 -- level correspondant à Dernier quartier
elseif(moonphase > 0.755 and moonphase < 1.00) then
level = 80 -- level correspondant à Dernier croissant
return level--moonPhase,
local geolocalisation = domoticz.settings.location.latitude..','..domoticz.settings.location.longitude
logWrite('geolocalisation : '..geolocalisation,domoticz.LOG_INFO)
local Forecast_url = "https://api.darksky.net/forecast/" -- url
local extraData = "?units=si&exclude=flags"--currently,minutely,daily,alerts,
if (item.isTimer) then
domoticz.openURL({
url = Forecast_url..DarkSkyAPIkey.."/"..geolocalisation..extraData,
callback = 'DarkSky_Trigger'
if (item.isHTTPResponse and item.ok) then
-- we know it is json but dzVents cannot detect this
-- convert to Lua
local json = domoticz.utils.fromJSON(item.data)
-- json is now a Lua table
if #item.data > 0 then
domoticz.data.Forecast = domoticz.utils.fromJSON(item.data)
rt = domoticz.utils.fromJSON(item.data)
domoticz.log("Problem with response from DarkSky (no data) using data from earlier run",domoticz.LOG_ERROR)
rt = domoticz.data.Forecast -- json empty. Get last valid from domoticz.data
if #rt < 1 then -- No valid data in domoticz.data either
domoticz.log("No previous data. are DarkSkyAPIkey and geolocalisation ok?",domoticz.LOG_ERROR)
return false
logWrite('heure systeme')
local now = domoticz.time.dDate
logWrite('now : '..now)
j = 1
for i = 1,48 do
logWrite('j : '..j)
if now > tonumber(json.hourly.data[j].time) then -- si maintenant est supérieur au timestamp lu
local h = domoticz.utils.round((now - tonumber(json.hourly.data[j].time)) / 3600,0)
logWrite("h : "..h)
j = j+h
logWrite("j : "..j)
logWrite('date :'.. os.date('%Y-%m-%d %H:%M:%S', json.hourly.data[j].time),domoticz.LOG_INFO)
logWrite('precipProbability :' ..json.hourly.data[j].precipProbability,domoticz.LOG_INFO)
if (proba_pluie_h[i]) then
domoticz.devices(proba_pluie_h[i]).updatePercentage(json.hourly.data[j].precipProbability*100)
local windSpeed = json.hourly.data[j].windSpeed
local windGust = json.hourly.data[j].windGust
local windBearing = json.hourly.data[j].windBearing
local temperature = json.hourly.data[j].temperature
local windChill = json.hourly.data[j].apparentTemperature
local direction = quadrants(windBearing)
logWrite('windSpeed : '..tostring(windSpeed)..' windGust : '..tostring(windGust)..' windBearing : '..tostring(windBearing)..' direction :'..tostring(direction)..' temperature : '..tostring(temperature)..' windChill : '..tostring(windChill),domoticz.LOG_INFO)
if (prev_wind_h[i]) then
domoticz.devices(prev_wind_h[i]).updateWind(windBearing,tostring(direction),windSpeed,windGust,temperature,windChill)
logWrite('mise à jour du device '..prev_wind_h[i],domoticz.LOG_INFO)
if j == 48 then break end
j = j +1
k = 1
for k = 1,8 do
local moonphase = json.daily.data[k].moonPhase
logWrite('moonPhase day ' ..k..' : '..tostring(moonphase))
logWrite(levelMoonhase(moonphase))
if(MoonPhaseSelect[k]) then
domoticz.devices(MoonPhaseSelect[k]).switchSelector(levelMoonhase(moonphase))
logWrite("update selector device")
if j == 8 then break end
j = j +1
