Find activation Device of Group
Posted: Friday 14 September 2018 13:45
by jannnfe
is there a way to get the name of the trigger of a group. There are several devices in a group. One of these is activated, which in turn activates the whole group. But now I want to find out which device has activated the group.
Tried to get the whole devices in group but nothing happend:
local deadDevices = domoticz.groups(item.name).devices().forEach(function(device)
return device.name
end)
print(deadDevices)
Re: Find trigger Device of Group
Posted: Friday 14 September 2018 17:45
by waaren
jannnfe wrote: Friday 14 September 2018 13:45
@jannnfe, when I test and activate one or some of the devices in a group, it does not activate the dzVents script with the on = groups section even when domoticz does show a status change. the script is only triggered when the group itself is turned "Off"or "On" Is that working differently at your installation or do I misinterpret your post?
if item is the group for where you want to look at the devices...
domoticz.groups(item.name).devices().forEach(function(device) -- loop over all devices in group
print ("Checking: " .. device.name .. " ; state: " .. device.state)
end)
Posted: Friday 14 September 2018 23:22
by jannnfe
Hey @waaren,
thanks for your reply.
I have a group "window contacts". This group contains all window contacts in my house as activation devices for the group.
So, if one of the activation devices in the group is activated, the group will also be activated automatically. That should actually be so by default.
And now I want to use dzVents to determine which activation device the group has activated.
I have extended your approach to test it. Although not exactly what I want to achieve but that does not work. Nothing is output in the log:
groups = {
'Fensterkontakte'
if(item.isGroup) then
if(item.active) then
if(item.name == 'Fensterkontakte') then
end)
Posted: Saturday 15 September 2018 0:54
by waaren
jannnfe wrote: Friday 14 September 2018 23:22
Please test script below to verify the observation I have with my domoticz systems, On my systems this script is not triggered if the group state is changed by one or more device changes but only when the group is directly switched "On" or "Off"
groups = {
'Fensterkontakte'
logging = {
level = domoticz.LOG_DEBUG,
marker = "groupStateChange"
dz.log("Checking: " .. device.name .. " ; state: " .. device.state,dz.LOG_DEBUG)
end)
Posted: Saturday 15 September 2018 2:02
by waaren
Digged a little deeper and hope I understand what your situation is better now. Assuming you have entered the window contacts both as group activators and as group members the following script will give you the name of the window contact that activated the group.
groups = {
'Fensterkontakte'
logging = {
local secondsAgo = 100
local activator
domoticz.log("Checking: " .. device.name .. " ; state: " .. device.state .. " lastUpdated: " .. device.lastUpdate.secondsAgo,domoticz.LOG_DEBUG)
if device.lastUpdate.secondsAgo < secondsAgo then
activator = device.idx
end)
domoticz.log("Activator is " .. domoticz.device(activator).name ,domoticz.LOG_DEBUG)
Posted: Saturday 15 September 2018 12:20
by waaren
(I think) Improved version that only looks at the activation devices.
groups = { 'Fensterkontakte' },
httpResponses = { "getsceneactivations" }},
logging = {
execute = function(dz, item)
local function triggerJSON()
local urlString = dz.settings['Domoticz url'] .. "/json.htm?type=command¶m=getsceneactivations&idx=" .. item.idx
dz.openURL({ url = urlString,
method = "GET",
callback = "getsceneactivations" })
local function getActivator()
if item.json.result ~= nil then
rt = item.json.result
dz.log("No values found",dz.LOG_DEBUG )
return
local activator = 0
for i=1,#rt do -- Loop through the result
dz.log( "Checking device " .. rt[i].idx .. " ===>> " .. dz.devices(rt[i].idx).name ,dz.LOG_DEBUG)
if dz.devices(rt[i].idx).lastUpdate.secondsAgo < secondsAgo then
activator = rt[i].idx
if activator == 0 then
dz.log("No activator found ",dz.LOG_DEBUG)
dz.log("The group activator is probably device " .. activator .. " (".. dz.devices(activator).name .. ")",dz.LOG_DEBUG)
if item.isGroup then
triggerJSON()
getActivator()
Re: Find activation Device of Group
Posted: Sunday 16 September 2018 10:56
by jannnfe
Hello @waaren,
Thank you! That was exactly what I was looking for. Thank you very much for your help, I really appreciate that
EDIT: One last thing. I have already tried a bit but found no solution. How do I get the group name in which the activator is additionally in the getActivator function?
Posted: Sunday 16 September 2018 15:29
by waaren
jannnfe wrote:
.. How do I get the group name in which the activator is additionally in the getActivator function?
In its current form the group name is not known to the script when it reaches the getActivator step.
So either use the groupname in a var and use that var in the on = section as groups trigger and somewhere in the getActivator function..(easiest)
Or store the item.name in dzVents persistent data
Please let me know if you cannot get it to work. In that case I will have a look later this week
Verstuurd vanaf mijn ONEPLUS A3003 met Tapatalk
Re: Find activation Device of Group [Solved]
Posted: Sunday 16 September 2018 21:23
by jannnfe
Hello, thank you, I have got it right now with persistent data. I added the following:
data = {
'groupName'
local activeGroup = domoticz.data.groupName
domoticz.data.groupName = item.name
Thank you!
