WsWin, lua-script to create ws_merge.csv
Posted: Thursday 13 September 2018 20:35
The weather software WsWin reads the data from a connected, compatible Personal Weather Station and processes that data for it's database and graphics, and (if desired) for uploads for other applications.
All very nice if your PWS has a balanced & complete set of sensors.
Unfortunately my PWS of type TFA_Nexus has a console-barometer which is 'less-than-excellent' and it misses a sensor for UVI.
The program WsWin has a functionality to look for an additional csv-file with supplementary data:
that supplementary data is then a replacement and/or addition for the data coming (or not) from TFA_Nexus.
Requires the creation of a file ws_merge.csv
The lua-script further down in this message performs that creation based on 'better' data available in Domoticz.
With this script-version the result is a file ws_merge.csv in directory /home/pi for inclusion of Barometric Pressure and UVI.
As indicated at the end of the script, YOU need to organise the required sync/upload to the location of the WsWin main directory.
Also YOU need to adjust the settings in WsWin to activate the link from WsWin to this file ws_merge.csv
Required actions to adjust those settings:
- Switch off 'File/Recording'
- at 'Weatherstation/Filewatching' set a mark for ws_merge.csv
- at 'Weatherstation/Available Sensors' also mark UVI
- if desired, at 'Internet/Sensors' mark UVI
- don't forget to switch on 'File/Recording'!
This lua-script may be applicable for other combinations than WsWin and TFA_Nexus, but generally bear in mind, that with the mechanism of ws_merge.csv you can only overwrite the sensors as listed in WsWin under tab 'Weatherstation/ AvailableSensors'
-- Script for Domoticz@Raspberry for creation of file ws_merge.csv for upload to WsWin linked to TFA_Nexus (or similar PWS)
-- (C)2018 Toulon7559, version for upload of barometric pressure + UVI for replacement/addition of data
-- Basic script-version to be tuned for YOUR Configuration of Domoticz
-- Line 06, Define input datasources within Domoticz & Settings
Barometer = 'BMP180_Temp_Baro'
UVMeter = 'UVN800'
Interval = 5 -- Interval in minutes
-- Line10, Get Current date & time from os as date.year, date.month, date.day, date.hour, date.min
date = os.date("*t")
year = date.year
month = date.month
if month < 10 then month = "0" .. month
day = date.day
if day < 10 then day = "0" .. day
hour = date.hour
if hour < 10 then hour = "0" .. hour
minutes = date.min
if minutes < 10 then minutes = "0" .. minutes
--Line 26, Read-out, Alignment & Compilation for BMP180 barometric pressure
sBMP180T, sBMP180B = otherdevices_svalues[Barometer]:match("([^;]+);([^;]+)")
sBMP180T = tonumber(sBMP180T);
sBMP180B = tonumber(sBMP180B);
a = 1 -- Relative correction for 'true' pressure, a is 0.9 till 1.1 for 10% offset
b = 0 -- Absolute correction for 'true' pressure, b is -10 till + 10 for -/+10 hPa
sBMP180B = (sBMP180B * a) + b
Line01text = string.format("%.2f", (sBMP180B))
-- Line 35, Readout UVI from UVN800
if UVMeter ~= '' then
UVI0= tonumber(otherdevices_uv[UVMeter])
Line02text= string.format("%.1f", UVI0)
-- Line 41, Make wsmerge_CSV-File for WsWin
-- Extracted (German) text from WsWin_Help-File:
-- Werden die ID‘s=135(Wind), 136(Windrichtung), 238(Helligkeit), 141(UV), 142(Solarstrahlung), 145(Windböen) verwendet,
-- dann werden die Merge-Daten nur übernommen, wenn keine Online Daten dafür vorhanden sind
-- Line 45, Define textsegments for wsmerge_CSV-File for WsWin
Line101text = ",,133,141" -- header with identifiers for overwrite in WsWin for relative air pressure and for UVI
Line102text = Line01text -- value for barometric pressure (hPa) linked to ID=133 (for unconditional overwrite)
Line103text = Line02text -- value for UVI (units) linked to ID=141
-- Line 50, Check interval-time and make csv-file
if (date.min % Interval == 0) then
file = io.open("/home/pi/ws_merge.csv", "w+")
-- Opens a file named ws_merge.csv (stored under the designated sub-folder of Domoticz)
-- File-creation in append mode
newline="\r\n" -- Line termination by 'return' + 'newline'
-- write 2 lines to opened file, each line closed by newline
file:write(Line101text .. newline)
file:write(day .. "." .. month .. "." .. year .. ",")
file:write(hour .. ":" .. minutes .. ",")
file:write(Line102text .. "," .. Line103text .. newline)
file:close() -- closes the open file
-- Line 64, next line is required to set permissions for open©&shift&execution of the file
os.execute("chmod a+rwx /home/pi/ws_merge.csv")
-- Line 66, Lua-Upload-script for ws_merge.csv to follow here
-- Otherwise you have to organise in a different way the sync/upload of ws_merge.csv towards the main directory of WsWin
