LMS playlist not working
Posted: Tuesday 11 September 2018 19:54
by Boredcat
All,
I am trying the use the LMS (Logitech Media Server) device in dzVents. I created the following script, which is activated using a switch named LMS.
It switches in the Squeezebox (Woonkamer) and receiver (device 76 and 74).
Squeebox and receiver switch on/off perfect depending on the LMS switch.
But I should also play playlist list1 and this fails.. (no errors in log) In Sqeezebox server the playlist is named list1
Any help .. Can't see what is wrong (looking at it for several days).
Running : V4.9697 (Beta)
devices = {
'LMS'
domoticz.log('Device ' .. device.name .. ' was changed', domoticz.LOG_INFO)
local LMS_S = domoticz.devices('LMS')
local LMS_P = domoticz.devices('Woonkamer')
local LMS_R = domoticz.devices(76)
if LMS_S.state == 'On' then
LMS_R.dimTo(25)
-- LMS_P.play()
LMS_P.startPlaylist('list1')
domoticz.log('PLAY list', domoticz.LOG_INFO)
--LMS_P.play()
if LMS_S.state == 'Off' then
domoticz.devices(74).switchOff()
LMS_P.switchOff()
LMS_R.dimTo(17)
Re: LMS playlist not working
Posted: Wednesday 12 September 2018 9:40
by waaren
Boredcat wrote: Tuesday 11 September 2018 19:54
.... But I should also play playlist list1 and this fails.. (no errors in log) In Sqeezebox server the playlist is named list1
What do you see in the log if you switch to debug for this script ?
devices = {
'LMS'
logging = { level = domoticz.LOG_DEBUG,
marker = "LMS playlist" },
Posted: Wednesday 12 September 2018 12:06
by Boredcat
Here the log.
Seems that list1 can not be found.
Checked again Sqeeuzebox server and under playlist there are 2 playlist list1 and list2
Using version 7.6.1
direct CLI command works perfect :
http://192.168.1.125:9000/status.html?p ... y&p2=list1
018-09-12 12:01:14.941 Status: dzVents: Info: LMS playlist: Device LMS was changed
2018-09-12 12:01:14.942 Status: dzVents: Debug: LMS playlist: Processing device-adapter for Woonkamer: Logitech Media Server device
2018-09-12 12:01:14.942 Status: dzVents: Debug: LMS playlist: Processing device-adapter for Woonkamer: Switch device adapter
2018-09-12 12:01:14.943 Status: dzVents: Debug: LMS playlist: Processing device-adapter for Reciever Woonkamer - Main Volume: Switch device adapter
2018-09-12 12:01:14.943 Status: dzVents: Debug: LMS playlist: Constructed timed-command: Set Level 25
2018-09-12 12:01:14.943 Status: dzVents: Debug: LMS playlist: Constructed timed-command: Play Playlist list1 TRIGGER
2018-09-12 12:01:15.033 Error: Logitech Media Server: Playlist 'list1 TRIGGER' not found.
Posted: Wednesday 12 September 2018 12:29
by waaren
Boredcat wrote: Wednesday 12 September 2018 12:06
Just for test purposes can you change the line
to
LMS_P.startPlaylist('list1').afterSec(1)
and again look at the log what the result is ?
Posted: Wednesday 12 September 2018 13:00
by Boredcat
No luck yet
2018-09-12 12:58:18.242 Status: User: Admin initiated a switch command (261/LMS/On)
2018-09-12 12:58:18.388 Status: dzVents: Info: LMS playlist: ------ Start internal script: LMS: Device: "LMS (Dummy)", Index: 261
2018-09-12 12:58:18.388 Status: dzVents: Info: LMS playlist: Device LMS was changed
2018-09-12 12:58:18.389 Status: dzVents: Debug: LMS playlist: Processing device-adapter for Woonkamer: Logitech Media Server device
2018-09-12 12:58:18.389 Status: dzVents: Debug: LMS playlist: Processing device-adapter for Woonkamer: Switch device adapter
2018-09-12 12:58:18.390 Status: dzVents: Debug: LMS playlist: Processing device-adapter for Reciever Woonkamer - Main Volume: Switch device adapter
2018-09-12 12:58:18.390 Status: dzVents: Debug: LMS playlist: Constructed timed-command: Set Level 25
2018-09-12 12:58:18.390 Status: dzVents: Debug: LMS playlist: Constructed timed-command: Play Playlist list1 TRIGGER
2018-09-12 12:58:18.390 Status: dzVents: Debug: LMS playlist: Constructed timed-command: Play Playlist list1 AFTER 1 SECONDS TRIGGER
2018-09-12 12:58:18.390 Status: dzVents: Info: LMS playlist: PLAY list
2018-09-12 12:58:18.390 Status: dzVents: Info: LMS playlist: ------ Finished LMS
2018-09-12 12:58:18.480 Error: Logitech Media Server: Playlist 'list1 TRIGGER' not found.
Posted: Thursday 13 September 2018 0:44
by waaren
Boredcat wrote: Wednesday 12 September 2018 13:00
No luck yet
And what is the result of
domoticz.sendCommand("Woonkamer","Play Playlist list1")
Posted: Thursday 13 September 2018 7:44
by Boredcat
domoticz.sendCommand("Woonkamer","Play Playlist list1") : Works
Any idea why this command is working and the dzVents not ? Should I report a bug ?
For now my issue is solved (will use the send command).
Posted: Thursday 13 September 2018 8:54
by waaren
Boredcat wrote: Thursday 13 September 2018 7:44
My guess is that one of the Lua scripts in dzvents/runtime is playing tricks on you but I can't figure out which one. Maybe because I am on the latest Beta. It is also kind of difficult for me to investigate further as I do not own a Logitech Media Server.
Before reporting this as a bug can you test on latest Beta ? If you see same behavior on that version, @dannybloe or one of the other developers might be able to explain what is causing this.
Posted: Friday 14 September 2018 9:25
by Boredcat
Updated to latest beta. Same behavior
Posted: Friday 01 February 2019 8:55
by Barberousse
It should work now on last beta (V4.10394) thanks to pull request
https://github.com/domoticz/domoticz/pull/2997
