Philips Hue Bridge + Osram Lightify + Domoticz?
Goldwing1973
Domoticz version: Stable
Post by Goldwing1973 »
I bought a couple of Osram Lightify GU10 bulbs, linking them to the Hue (v2) bridge was easy, but they arn't showing as devices in Domoticz.
Am i doing something wrong or is this a Osram Lightify bulbs + Hue problem?
Even the scene i made in the Hue app isn't showing in Domoticz
Over 50 Z-Wave Devices (Fibaro and Neo), 4xLogitech Hub, 2xPhilips Hue Bridge+55 Lights, 1x Nest Thermostat, 2xNetatmo Weather Station, 1xSkybell v1 Doorbell, 3 Kwikset KEVO Doorlocks and Domoticz running on a Intel NUC
Goldwing1973
Re: Philips Hue Bridge + Osram Lightify + Domoticz?
Update, i have also a Home Assistant running, and there the Osram Lights are visable.
So apparantly its Domoticz not accepting the Lights from the Hue Bridge.
Is there a way to force the Lights to be accepted by Domoticz?
Goldwing1973 wrote: Monday 10 September 2018 22:23 I bought a couple of Osram Lightify GU10 bulbs, linking them to the Hue (v2) bridge was easy, but they arn't showing as devices in Domoticz.
Hue Bridge devices /scenes not picked up by domoticz is reported as a problem in latest stable and solved in later Beta's. It will not be solved for V4.9700, so either wait for next stable of move to Beta.
Goldwing1973
waaren wrote: Tuesday 11 September 2018 8:30
Ok, thanks for the info, i'll wait then for the next stable.
Smiggel
Domoticz version: 4.9700
Post by Smiggel »
So, I guess still also counts for IKEA TRÅDFRI with the Hue Bridge? I have the exact same kind of issue. Lights work perfectly with the hue bridge. Right out of the box. Just the lights don't show up in Domoticz.
Jem101
Post by Jem101 »
I have a similar but odd situation as well. I have a pair of IKEA TRÅDFRI colour changing bulbs and even one of their LED drivers. I have managed to add all of these to my Hue hub successfully and they have all shown up in Domoticz and are controllable.
Recently I have purchased three of the IKEA TRÅDFRI candle bulbs and although I have added them to the Hue hub, these do not appear in Domoticz.
I am running the latest Domoticz beta and have restarted a couple of times but with no luck.
Weird or what?
I firmly believe in having an open mind - although not so open that your brain falls out!
- sometimes attributed to Carl Sagan, but the original quote is much older than that
