doorbell script
Posted: Monday 10 September 2018 21:20
by snellejellep
dear forum users,
i have a wish and i do not know how to realize it, i have a button connected to domoticz which i want to use as a doorbell, when the doorbell is pressed i want some lights to flash, but is there a possibility to store the state of the light, activate a doorbell scene and after the scene restore the state off the lights.
for as far as i know this should be possible in dzvents but i do not know how to do that.
i hope someone can help me, thanks in advance!
Re: doorbell script
Posted: Monday 10 September 2018 21:29
by waaren
snellejellep wrote: Monday 10 September 2018 21:20 i have a wish and i do not know how to realize it, i have a button connected to domoticz which i want to use as a doorbell, when the doorbell is pressed i want some lights to flash, but is there a possibility to store the state of the light, activate a doorbell scene and after the scene restore the state off the lights.
@snellejellep, Should be possible but some questions:
- are these standard on/off, -dimlights or rgbw type of lights
- howto "flash" these lights? Simple on/off or something else ?
Re: doorbell script
Posted: Monday 10 September 2018 21:40
by snellejellep
I use philips hue lights, some are rgb, some just white, i tought about just flashing the white ones and letting the rgb ones flash red, the color change is what makes it difficult i think.
Also i wanted to use the data from my motion sensors to let the lights flash only in the rooms people are
But first wanted to start with just the flashing
Re: doorbell script
Posted: Monday 10 September 2018 22:37
by HansieNL
Maybe you can take a look at the HUE API. https://www.developers.meethue.com/docu ... ng-started
With a curl command a lot is possible:
curl -H "Accept: application/json" -X PUT --data '{"alert":"select"}' http://<hue-bridge-ip>/api/<hue-username>/lights/4/state
Re: doorbell script
Posted: Tuesday 11 September 2018 1:02
by waaren
snellejellep wrote: Monday 10 September 2018 21:40
Maybe this example script will help in what you want to achieve. Another line of approach could be to trigger an IFTTT applet from this dzVents script.
-- doorbell actions
    on = { devices = {"Doorbell" } },
    logging =   {       level   =   domoticz.LOG_DEBUG,                  -- switch to LOG_INFO when results are OK
                        marker  =   "doorbell actions" },
    execute = function(dz, trigger)
        if trigger.state == "Off" then -- No action needed when doorbell switch back to Off state
            return
        local rgbwLights    = {"Hue lightstrip","Hue Go","Hue rgbw1","Hue etc"}        -- table with rgbwlights that need to flash red
        local whiteLights   = {"lamp1","lamp2","lamp999"}                             -- table with white lights that need to flash
        local function flashRGBWLights()
            local redflashDelay = 20 		-- delay in seconds
            for i = 1,#rgbwLights do  		-- walk the table from first (1) to last (#rgbwLights)
                local loopDevice = dz.devices(rgbwLights[i])
                local colorTable = dz.utils.fromJSON(loopDevice.color)
                dz.log(loopDevice.name .. " ;state ===>> " .. loopDevice.state,dz.LOG_DEBUG)
                loopDevice.setRGB(255,0,0)                                                  -- Turn to RED
                loopDevice.switchOn()
                loopDevice.setRGB(colorTable.r, colorTable.g, colorTable.b).afterSec(redflashDelay)
                if loopDevice.state == "Off" then
                    dz.log("Schedule switchOff for " .. loopDevice.name,dz.LOG_DEBUG)
                    loopDevice.switchOff().afterSec(redflashDelay)
        local function flashWhiteLights()
            local whiteflashDelay = 1 -- delay in seconds
            for i = 1,#whiteLights do -- walk the table
                local loopDevice = dz.devices(whiteLights[i])
                local state      = loopDevice.state
                    loopDevice.switchOff().afterSec(whiteflashDelay)
                    loopDevice.switchOn().afterSec(whiteflashDelay)
        flashRGBWLights()
        flashWhiteLights()
Re: doorbell script
Posted: Tuesday 11 September 2018 19:24
by snellejellep
thank you, it works great!
Re: doorbell script
Posted: Monday 06 November 2023 23:34
by mojso
waaren wrote: Tuesday 11 September 2018 1:02
-- doorbell actions
            return
        flashRGBWLights()
        flashWhiteLights()
the script works great but the brightness stays at 100 percent, can it be returned to the preset brightness of the rgb lights
