If you leave it running for some time you can find out at what time data is write to the SD-card and/or USB stick.
This way you can optimize the amount of data written to hardware and expand the lifetime of the SD-card and/or USB stick.
The explanation is in the script.
Scriptname: media-statistics.lua
Prerequisits
Domoticz v4.9700 or later (dzVents version 2.4 or later)
-- Author -----------------------------------------------------------------
V1.0 - Eddy Geurts
-- Devices ----------------------------------------------------------------
Create virtual hardware: Dummy (Does nothing, use for virtual switches only)
Create set of 2 virtual sensors (use button on the just created virtual device)
Types: Custom Sensor
Custom Sensor
One set of 2 Devices for SD-card (device: /dev/mmcblk0)
If available one set of 2 Devices for USB stick (device: /dev/sda)
If available one set of 2 Devices for USB stick (device: /dev/sdb)
Device name Axis label
SD-card number of writes Writes
SD-card writes Kb Kb
SDA number of writes Writes
SDA writes Kb Kb
SDB number of writes Writes
SDB writes Kb Kb
If needed, delete below the code of the device(s) that are NOT used.
-- /sys/block/<dev>/stat --- output ----------------------------------------
Field Name units description
1 read I/Os requests number of read I/Os processed
2 read merges requests number of read I/Os merged with in-queue I/O
3 read sectors sectors number of sectors read
4 read ticks milliseconds total wait time for read requests
5 write I/Os requests number of write I/Os processed
6 write merges requests number of write I/Os merged with in-queue I/O
7 write sectors sectors number of sectors written
8 write ticks milliseconds total wait time for write requests
9 in_flight requests number of I/Os currently in flight
10 io_ticks milliseconds total time this block device has been active
11 time_in_queue milliseconds total wait time for all requests
'sectorsize' can be found by 'sudo fdisk -l' and is mostly 512 (bytes)
active = true,
-- active = false,
['timer'] = { 'every 5 minutes', }
-- ['timer'] = { 'every minute', }
logging = {
level = domoticz.LOG_INFO,
marker = "Media"
data = {
SDcardCounter = {initial=0},
SDcardBytes = {initial=0},
SDACounter = {initial=0},
SDABytes = {initial=0},
-- SDBCounter = {initial=0},
-- SDBBytes = {initial=0}
execute = function(domoticz)
function mysplit(inputstr, sep)
if sep == nil then
sep = "%s"
local t={} ; i=1
for str in string.gmatch(inputstr, "([^"..sep.."]+)") do
t[i] = str
i = i + 1
return t
local f, line, results, result
local sectorsize = 512 -- change if necessary
-- Device mmcblk0
if domoticz.devices("SD-card number of writes").isDevice and domoticz.devices("SD-card writes Kb").isDevice then
f = io.popen("cat /sys/block/mmcblk0/stat")
line = f:read("*a")
f:close()
results = mysplit(line, " ")
result = results[5] - domoticz.data.SDcardCounter
if result < 0 then result = 0 end
domoticz.devices("SD-card number of writes").updateCustomSensor(result)
result = domoticz.utils.round(((results[7] - domoticz.data.SDcardBytes) * sectorsize) / 1024)
domoticz.devices("SD-card writes Kb").updateCustomSensor(result)
domoticz.log("SD-card: " .. (results[5] - domoticz.data.SDcardCounter) .. " writes with " .. result .. " Kb")
domoticz.data.SDcardCounter = results[5]
domoticz.data.SDcardBytes = results[7]
-- Device SDA
if domoticz.devices("SDA number of writes").isDevice and domoticz.devices("SDA writes Kb").isDevice then
f = io.popen("cat /sys/block/sda/stat")
line = f:read("*a")
f:close()
result = results[5] - domoticz.data.SDACounter
domoticz.devices("SDA number of writes").updateCustomSensor(result)
result = domoticz.utils.round(((results[7] - domoticz.data.SDABytes) * sectorsize) / 1024)
domoticz.devices("SDA writes Kb").updateCustomSensor(result)
domoticz.log("SDA: " .. (results[5] - domoticz.data.SDACounter) .. " writes with " .. result .. " Kb")
domoticz.data.SDACounter = results[5]
domoticz.data.SDABytes = results[7]
-- Device SDB
-- if domoticz.devices("SDB number of writes").isDevice and domoticz.devices("SDB writes Kb").isDevice then
-- f = io.popen("cat /sys/block/sdb/stat")
-- line = f:read("*a")
-- f:close()
-- results = mysplit(line, " ")
-- result = results[5] - domoticz.data.SDBCounter
-- if result < 0 then result = 0 end
-- domoticz.devices("SDB number of writes").updateCustomSensor(result)
-- result = domoticz.utils.round(((results[7] - domoticz.data.SDBBytes) * sectorsize) / 1024)
-- domoticz.devices("SDB writes Kb").updateCustomSensor(result)
-- domoticz.log("SDB: " .. (results[5] - domoticz.data.SDBCounter) .. " writes with " .. result .. " Kb")
-- domoticz.data.SDBCounter = results[5]
-- domoticz.data.SDBBytes = results[7]
-- end
