outside temperature sensor ; unknown codec 433Mhz
snuiter
Post by snuiter »
I have a weather station including an outside temperature sensor. This sensor is using the 433Mhz so I was hoping I could receive the values with my 433Mhz transceiver(RFXcom rfxtrx-e )
Anyone suggestions how I can find the right code and/or receive the values in my domoticz system?
This is my setup
rPi2 - domoticz latest beta
RFXtrx433 ext2 ; fw-version 2015
weather station is a nor-tec 73383
Any idea how I can find the right setting ?
I have raised this question with rfxcom support, but any help is appreciated
SweetPants
Re: outside temperature sensor ; unknown codec 433Mhz
Post by SweetPants »
First question, did you check the supported device list? http://www.rfxcom.com/epages/78165469.s ... /Downloads
snuiter
Post by snuiter »
Hi Sweetpants,
I did, couldn't find it that is correct but as there is so much on the list and there is not a real clear brand on the weatherstation I wanted it to give a try. b_weijenberg also gave me some tips but didn't see the temperature sensor getting added to my device list. I guess it is a custom protocol.
Thanks for the help all .
