Domoticz + RPI3b+ hanging
Posted: Tuesday 04 September 2018 22:48
Hi I am trying to get Domoticz I stalled on a Raspberry Pi3b+ with PoE hat. So far I have been trying this for 4 days without success.
I first tried copying the Raspbian image to the SD card and then installing Domoticz the 'hard way' but when running the make -j 3 command it gets to 22% and the entire Pi hangs completely.
I then tried putting updated NOOBS on the card having wiped it and then choosing Raspbian in the setup. This completed and I updated and upgraded to all current updates but with the same output.
In all instances I have updated everything to current levels, boost libraries are 1.68. I have also tried updating cmake to current level but again it hits 22% and just hangs - the Pi is completely unresponsive and after leaving it for 2 hours it was still at the same point leaving power removal the only option.
I have previously completed this on a Pi 3b, the only reason I have upgraded is for PoE but I have ruled that out as the problem as I get the same results with the PoE hat removed.
Has anyone managed to get Domoticz installed on a 3b+ the 'hard way' as yet? Trying to figure out if it's just not compatible for some reason or if I have a faulty Pi - it seems to work ok with everything else I have tried on it though and I know the SD card is good.
Sent from my ONEPLUS A5010 using Tapatalk
