using Domoticz with on/off relay from Honeywell BDR91
Posted: Sunday 02 September 2018 23:33
After some search in here and on Google, could not find a relevant doc about this topic, so better to ask.
I have and already installed Honeywell BDR91 (on/off relay for Boiler) and want to control this via Domoticz. As it was working with 868Mhz, I recently installed a RFLink 868 Mhz Gateway (from Nodo) to Domoticz but I cannot detect the relay. Try to manually on/off it via the button but still not seen by Domoticz.
Anybody using such a configuration? Am I missing something? I am a bit new on Domoticz so any pointer is much appreciated.
As OTGW is out of stock on Nodo I am for now stuck with BDR91. If there is any alternative OTGW that I can install that can also be a solution.
Some details in case it helps to understand what I am trying to do:
- Bolier is Remeha Calenta
- I want to control the boiler to start / stop heating
- I have temp sensors in each room and z-wave controlled radiator thermostats. So based on room temperature and desired temp set on the thermostats, I want to start boiler and adjust the thermostats for each radiator to heat / not to heat rooms.
I am open to any idea or any LUA script that I can use as a sample / starting point to achieve my solution
Thanks in advance and kind regards.
-SNK
-SNK
