How to add an Arilux RGB Controller Wifi
DarkG
Domoticz version: 4.10076
Post by DarkG »
I bought from ebay a RGB Wifi Controller. Don´t know if it is a clone or not.
Seems to be a LC03. Works with Magic Home Android App too.
First I looked inside the case. The ESP is integrated in PCB. Its a closed Circuit and not like the others with an ESP PCB.
I got other Problems too, but first of all how can I connect it with Domo?
I created an Arilux Hardware Device with the right IP, then create a Device and give it a name.
But after that there is no switch or else in Switches. All is clear.
I started add new devices too. Can only see in Log this.
018-09-01 12:51:01.915 Status: Arilux stopped
2018-09-01 12:51:05.884 Status: Arilux Worker started...
2018-09-01 12:51:26.011 (rgb) Color Switch ()
2018-09-01 12:51:26.008 Status: Arilux: New controller added (192.168.0.55/rgb testr)
2018-09-01 12:51:42.070 Status: New sensors allowed for 5 minutes...
2018-09-01 12:51:48.907 Status: User: Cino initiated a switch command (20/rgb testr/On)
2018-09-01 12:51:48.908 Status: Arilux: Sending data to device
2018-09-01 12:51:49.125 (rgb) Color Switch (rgb testr)
2018-09-01 12:51:52.602 (rgb) Color Switch (rgb testr)
2018-09-01 12:51:52.451 Status: User: Cino initiated a switch command (20/rgb testr/Off)
2018-09-01 12:51:52.451 Status: Arilux: Sending data to device
And now my other Problem. It could be the device is broken. I tested 2 different rgb stripes. When I choose Red as an example the Blue channel doesnt complete gets down. And I could not turn off all. Green will be not shut off.
Does anybody have the same problems?
RPi4 Shelly1 Shelly2.5 ESPEasy Tuya Domoticz Beta Dashticz 3.6
TryDomotic
Re: How to add an Arilux RGB Controller Wifi
Post by TryDomotic »
I'm new in domotic. I installed my Raspi 6 month ago with Raspbian and then start to play : manage some lights, airconditioner and blinds.
I try and take time to understand and find the right way to proceed. That's funny and love that; But ... because there is always a but ....
I encounter exactly the same issue with an Arilux-LC09 (RGB) recently purchased.
I add the hardware without issue (looks like), then add light and Domotics said "device created and available under switch"
BUT ....
but, nothing in device list.
Did someone found a solution ?
Thanks for your help.
TryDomotic
None of you have an answer or at least any idea on how to proceed ?
Suprising as these products are probably one of the most widespread in Amazon to use led strips.
Hope someone will be able to adress the point.
Thanks per advance.
Hanss
Post by Hanss »
The same over here. Arilux does not work for 100 procent. :-(
I can add the controllers and manually it is possible to turn on/off the lights (led strips), but the timers don't work.
