Whan I type in a browces command:
http://192.168.1.5:8080/json.htm?type=c ... itchcmd=On
I got response:
"status" : "OK",
"title" : "SwitchLight"
However, it doesn't change the state of the switch in Domoticz. What I do wrong?
Thanks.
JSON commands
Adso76
JSON commands
Domoticz Version: 4.9895 running on Raspberry Pi B 3+ (Raspbian). PCF8574 as input and output.
- Egregius
- Domoticz version: v2024.7
Re: JSON commands
You should use a code block, now the url is showed shortened.
Adso76
Re: JSON commands
http://192.168.1.5:8080/json.htm?type=command¶m=switchlight&idx=2&switchcmd=On
- philchillbill
Re: JSON commands
Your syntax looks correct. Are you sure your idx is relevant?
Adso76
Re: JSON commands
Thanks! Originally I took IDX from Setup / hardware, when I looked at Setup / devices I found out that my device has different IDX there. After changing JSON command works fine!
BTW It's confusing that device has different IDX than hardware connected with this device.
