Electric energy calculation using only usage(watts)?
gajotnt
Domoticz version: V4.9700
Post by gajotnt »
Hello there, is there anyway to have domoticz receive power used (watts) and then calculate the energy usage?
I have a "Total" energy/usage counter, and a "Solar" energy/usage counter, they both work great, but i wanted to have a idea of how much energy i waste, so i tweaked a LUA script to update a "Waste" energy/usage counter, the problem is it registers the wasted energy but doesnt calculate the energy usage based on the value of the wasted energy.
I read somewere that LUA doesnt work correctly when calculating energy usage, and efectivly it does not do the computation, it just takes the energy value from the other counter, is there anyway to make this work on dzvents?
Thanks in advance :)
-- Get current date & time
t1 = os.time()
local currentDate = os.date("*t");  -- sets up currentDate.[table]
-- (currentDate.year [full], .month [1-12], .day [1-31], .hour [0-23], .min [0-59], .sec [0-59], .wday [0-6 {Sun-Sat}])
sCurrentTime = currentDate.year .. "-" .. currentDate.month .. "-" .. currentDate.day .. " " .. currentDate.hour .. ":" .. currentDate.min .. ":" .. currentDate.sec
function update(device, id, power, energy, index)
commandArray[index] = {['UpdateDevice'] = id .. "|0|" .. power .. ";" .. energy}
TotalPowerUsage, TotalEnergyUsage = otherdevices_svalues["Total"]:match("([^;]+);([^;]+)")
if tonumber(TotalPowerUsage) <=0  then
WastePowerBalance = -(TotalPowerUsage)
WasteEnergyBalance = TotalEnergyUsage
if tonumber(TotalPowerUsage) >=1  then
WastePowerBalance = 0
update("Waste", 98, WastePowerBalance, WasteEnergyBalance, 2) -- 98 is the ID of the dummy incoming device
gajotnt
Re: Electric energy calculation using only usage(watts)?
Post by gajotnt »
Did lots and lots of reading and trial and error finally got this working
So "Total" is my main Electricity counter (SDM120) that gives me positive and negative values (when solar panels producing more than the house consumes).
The idea is that i have a register of how many Euros I have wasted by not using 100% of the Solar Power. Since i have a Sonoff POW telling me how much they generated, this way i can subtract the wasted from the generated and really know my savings from solar power.
"Wasted" dummy device must be an Electric (Instant + Counter) and energy read must be set to compute
	          devices = {
         'Total' --Name of the counter you are reading from (this ensures your new dummy device gets updated when this one is)
		    if domoticz.devices('Total').WhActual < -1 then --change total to your device name
		       currentpower = -(domoticz.devices('Total').WhActual) --turns the negative value to positive and defines the variable from the main counter
		        domoticz.openURL({
                        url = 'http://127.0.0.1:8080/json.htm?type=command&param=udevice&idx=98&nvalue=0&svalue='..currentpower..';0', --idx=98 is my Waste counter ID, set this by your setup
                        method = 'GET'})
                		        domoticz.openURL({
                        url = 'http://127.0.0.1:8080/json.htm?type=command&param=udevice&idx=98&nvalue=0&svalue=0;0',
                        method = 'GET'})
karibe66
Post by karibe66 »
Thank you very much for sharing it!!
I was getting crazy trying to make domoticz compute energy, many days and no way with LUA script
This is very helpful for me
