Monitor Synology NAS with SNMP
papoo
Domoticz version: 4.10
Post by papoo »
this script is not necessarily successful, do not hesitate to propose improvements, optimizations
2018-08-24 18_31_58-Domoticz.png (24.57 KiB) Viewed 12089 times
For this script to work you need to enable SNMP on your synology NAS and install SNMP on your Raspberry Pi
Enable SNMP on your synology NAS
Go toMain Menu>Control Panel >SNMP to enable SNMP service, which allows users to monitor
Synology DiskStation network flow with the network management software.
You can use V1/V2
And set a password (Community)
Install SNMP on Raspberry Pi
Log in to you Raspberry Pi and issue:
sudo apt-get install snmpd
Reboot your Pi:
sudo reboot
Check if SNMP is up and running, issue:
snmpget -v 2c -c PASSWORD -O qv NASIPADDRESS 1.3.6.1.4.1.6574.1.5.1.0
Replace PASSWORD with the Community name you entered while setting up your NAS
Replace NASIPADDRESS with the ip address of your NAS
You should get something like this:
"DS218+" which corresponds to your Synology Model
test
snmpget -v 2c -c PASSWORD -O qv NASIPADDRESS 1.3.6.1.2.1.25.2.3.1.5.31
snmpget -v 2c -c PASSWORD -O qv NASIPADDRESS 1.3.6.1.2.1.25.2.3.1.5.38
snmpget -v 2c -c PASSWORD -O qv NASIPADDRESS 1.3.6.1.2.1.25.2.3.1.5.41
then modify OID_HDUnit, OID_HDTotal, OID_HDUsed variables (.38 on DSM 5.1, .41 on DSM 6.0+ or .31 on my new DS218)
if you have à DS2XX model, uncomment -- local OID_HDtemp2='1.3.6.1.4.1.6574.2.1.1.6.1' to show the hdd2 temperature
Then create:
1 device Switch
x temperature device
3 percent devices
1 meter device
all you have to do is create a Synology.lua file that you will put in /home/pi/domoticz/scripts/dzVents/scripts/Synology.lua
you will customize the following code
auteur : papoo
creation : 17/02/2019
mise à  jour : 05/04/2019
https://pon.fr/dzvents-supervision-dun-nas-synology-avec-snmp/
https://github.com/papo-o/domoticz_scripts/blob/master/dzVents/scripts/synology2.lua
https://easydomoticz.com/forum/viewtopic.php?f=17&t=7022
https://www.domoticz.com/forum/viewtopic.php?f=59&t=24618
You can use V1/V2
Reboot your Pi:
sudo reboot
how to choose disk capacity to monitor?
snmpwalk -v 2c -c PASSWORD NASIPADDRESS 1.3.6.1.2.1.25.2.3.1.3
results of my DS218 :
HOST-RESOURCES-MIB::hrStorageDescr.1 = STRING: Physical memory
HOST-RESOURCES-MIB::hrStorageDescr.3 = STRING: Virtual memory
HOST-RESOURCES-MIB::hrStorageDescr.6 = STRING: Memory buffers
HOST-RESOURCES-MIB::hrStorageDescr.7 = STRING: Cached memory
HOST-RESOURCES-MIB::hrStorageDescr.8 = STRING: Shared memory
HOST-RESOURCES-MIB::hrStorageDescr.10 = STRING: Swap space
HOST-RESOURCES-MIB::hrStorageDescr.31 = STRING: /
HOST-RESOURCES-MIB::hrStorageDescr.36 = STRING: /tmp
HOST-RESOURCES-MIB::hrStorageDescr.37 = STRING: /run
HOST-RESOURCES-MIB::hrStorageDescr.38 = STRING: /dev/shm
HOST-RESOURCES-MIB::hrStorageDescr.39 = STRING: /sys/fs/cgroup
HOST-RESOURCES-MIB::hrStorageDescr.40 = STRING: /run/cgmanager/fs
HOST-RESOURCES-MIB::hrStorageDescr.51 = STRING: /volume1
HOST-RESOURCES-MIB::hrStorageDescr.54 = STRING: /volume1/@docker/btrfs
then modify     OID_HDUnit, OID_HDTotal, OID_HDUsed variables with your last number choice (.38 on DSM 5.1, .41 on DSM 6.0+ or .51 on my new DS218)
Then create:
1 device Switch
1 temperature device
3 percent devices
x meter device
-------------Fonctions----------------------
function format(str)
   if (str) then
      str = string.gsub (str, " Bytes", "")
      str = string.gsub (str, " kB", "")
   return str
-------------Fin Fonctions-----------------
    local NasIp = "diskstation2"                            -- NAS IP Address
    local CommunityPassword = "synology"                    -- SNMP Password
    local NAS = "Synology"                                  -- NAS Switch
    local NAS_TEMP = "Synology Temp"
    local NAS_CPU = "Synology Utilisation CPU"              -- NAS CPU
    local NAS_MEM = "Synology Utilisation RAM"              -- NAS MEM
    local NAS_HD_SPACE_PERC = "Synology Occupation Disque"  -- NAS HD Space  in %
    local NAS_HD_SPACE = "Synology Espace Disponible"       -- NAS HD Space  in Go (custom sensor)
    local NAS_HDD1_TEMP = "Synology HDD1 Temp"              -- NAS HD1 Temp, nil si inutilisé
    local NAS_HDD2_TEMP = nil                               -- NAS HD2 Temp, nil si inutilisé
    local NAS_HDD3_TEMP = nil                               -- NAS HD3 Temp, nil si inutilisé
    local NAS_HDD4_TEMP = nil                               -- NAS HD4 Temp, nil si inutilisé
    local OID_NAS_TEMP = '1.3.6.1.4.1.6574.1.2.0'
    local OID_HDUnit = '1.3.6.1.2.1.25.2.3.1.4.51'          -- OID HD Unit Change OID to .38 on DSM 5.1 or .41 on DSM 6.0+ or .51 on my DS218
    local OID_HDTotal = '1.3.6.1.2.1.25.2.3.1.5.51'         -- OID Total space volume in Go Change OID to .38 on DSM 5.1 or .41 on DSM 6.0+ or .51 on my DS218
    local OID_HDUsed = '1.3.6.1.2.1.25.2.3.1.6.51'          -- OID Space used volume in Go Change OID to .38 on DSM 5.1 or .41 on DSM 6.0+ or .51 on my DS218
    local OID_CpuUser = '1.3.6.1.4.1.2021.11.9.0'           -- OID CPU user
    local OID_CpuSystem = '1.3.6.1.4.1.2021.11.10.0'        -- OID CPU System
    local OID_MemAvailable = '1.3.6.1.4.1.2021.4.13.0'      -- OID Free Memory Available
    local OID_MemTotalSwap = '1.3.6.1.4.1.2021.4.3.0'       -- OID MemTotalSwap
    local OID_MemTotalReal = '1.3.6.1.4.1.2021.4.5.0'       -- OID MemTotalReal
    local OID_MemTotalFree = '1.3.6.1.4.1.2021.4.11.0'      -- OID MemTotalFree
    local OID_HDtemp1 = '1.3.6.1.4.1.6574.2.1.1.6.0'        -- OID Temperature HDD1
    local OID_HDtemp2 = '1.3.6.1.4.1.6574.2.1.1.6.1'        -- OID Temperature HDD2
    local OID_HDtemp3 = '1.3.6.1.4.1.6574.2.1.1.6.2'        -- OID Temperature HDD3
    local OID_HDtemp4 = '1.3.6.1.4.1.6574.2.1.1.6.3'        -- OID Temperature HDD4
    --local OID_Raid_Status = '1.3.6.1.4.1.6574.3.1.1.3.0'        -- OID Raid Status
    --local OID_Physical_Memory_Units = '1.3.6.1.2.1.25.2.3.1.4.1'
    --local OID_Physical_Memory_Size = '1.3.6.1.2.1.25.2.3.1.5.1'
    --local OID_Physical_Memory_Used = '1.3.6.1.2.1.25.2.3.1.6.1'
    --local OID_system_memory_total = '1.3.6.1.4.1.2021.4.5.0'
    --local OID_system_memory_free = '1.3.6.1.4.1.2021.4.6.0'
    --local OID_system_vsmemory_shared = '1.3.6.1.4.1.2021.4.13.0'
    --local OID_system_vsmemory_buffer = '1.3.6.1.4.1.2021.4.14.0'
    active = true,
    timer = {'every minute'}
   -- on = { devices = { "your trigger device" }},
  logging =   {   level    =   domoticz.LOG_DEBUG,                                             -- Seulement un niveau peut être actif; commenter les autres
                -- level    =   domoticz.LOG_INFO,                                            -- Only one level can be active; comment others
                -- level    =   domoticz.LOG_ERROR,
                -- level    =   domoticz.LOG_MODULE_EXEC_INFO,
                marker    =   "Synology Monitor v1.35 "      },
    execute = function(dz)
        local i = 0
        local results = {}
        local command = 'snmpget -v 2c -c '..CommunityPassword..' -O qv '..NasIp..' '..OID_NAS_TEMP..' '..OID_HDUnit..' '..OID_HDTotal..' '..OID_HDUsed..' '..OID_CpuUser..' '..OID_CpuSystem..' '..OID_MemAvailable ..' '.. OID_MemTotalSwap ..' '..OID_MemTotalReal..' '..OID_MemTotalFree..' '..OID_HDtemp1..' '..OID_HDtemp2..' '..OID_HDtemp3..' '..OID_HDtemp4--..' '..OID_Physical_Memory_Units ..' '..OID_Physical_Memory_Used..' '..OID_Physical_Memory_Size ..' '..OID_system_memory_total ..' '..OID_system_memory_free ..' '.. OID_system_vsmemory_shared ..' '.. OID_system_vsmemory_buffer
        local handle = assert(io.popen(command))
        for line in handle:lines() do
            results[i] =  format(line)
            i = i + 1
        handle:close()
        if results[0] then
            dz.log("NASTemp : "..results[0],dz.LOG_DEBUG)
            if NAS_TEMP then dz.devices(NAS_TEMP).update(0,results[0]) end
        if results[1] then dz.log("HDUnit : "..results[1],dz.LOG_DEBUG) end
        if results[2] then dz.log("HDTotal : "..results[2],dz.LOG_DEBUG) end
        if results[3] then dz.log("HDUsed : "..results[3],dz.LOG_DEBUG) end
        if results[4] then dz.log("CpuUser : "..results[4],dz.LOG_DEBUG) end
        if results[5] then dz.log("CpuSystem : "..results[5],dz.LOG_DEBUG) end
        if results[1] and results[2] then
           HDTotalGo = dz.utils.round((results[2] *  results[1] / 1024 / 1024 / 1024/1024),2)
           dz.log("HDTotalGo : "..HDTotalGo,dz.LOG_DEBUG)
         if results[1] and results[3] then
           HDUsedGo = dz.utils.round(((results[3]) *  results[1] / 1024 / 1024 / 1024/1024), 2)
        if results[1] and results[2] and results[3] then
            HDFreeGo = dz.utils.round(((results[2] - results[3]) *  results[1] / 1024 / 1024 / 1024/1024),2)
        if HDFreeGo then
            dz.log("HDFreeGo : "..HDFreeGo,dz.LOG_DEBUG)
            dz.devices(NAS_HD_SPACE).update(0,HDFreeGo)
        if results[2] and results[3] then
            HDFreePerc = dz.utils.round(((results[3] * 100) / results[2]), 0)
        if HDFreePerc then
            dz.log("HDFreePercent : "..HDFreePerc,dz.LOG_DEBUG)
            dz.devices(NAS_HD_SPACE_PERC).update(0,HDFreePerc)
        if results[4] and results[5] then
            CpuUsed = (results[4] + results[5])
        if CpuUsed then
            dz.log("CpuUsed : "..CpuUsed,dz.LOG_DEBUG)
            dz.devices(NAS_CPU).update(0,CpuUsed)
        if results[7] then
            dz.log("memTotalSwap: "..tostring(results[7]),dz.LOG_DEBUG)
        if results[8] then
            dz.log("memTotalReal: "..tostring(results[8]),dz.LOG_DEBUG)
        if results[9] then
            dz.log("memTotalFree: "..tostring(results[9]),dz.LOG_DEBUG)
        if results[7] and results[8] and results[9] then
            MemUsedPerc = dz.utils.round(100-results[9]*100/(results[7]+results[8]), 0)
        if MemUsedPerc then
            dz.log("MemUsedPercent : "..MemUsedPerc,dz.LOG_DEBUG)
            dz.devices(NAS_MEM).update(0,MemUsedPerc)
        if results[10] then
            dz.log("HDTemp1 : "..tostring(results[10]),dz.LOG_DEBUG)
            if NAS_HDD1_TEMP ~= nil then dz.devices(NAS_HDD1_TEMP).update(0,results[10]) end
        if results[11] then
            dz.log("HDTemp2 : "..tostring(results[11]),dz.LOG_DEBUG)
            if NAS_HDD2_TEMP ~= nil then dz.devices(NAS_HDD2_TEMP).update(0,results[11]) end
        if results[12] then
            dz.log("HDTemp3 : "..tostring(results[12]),dz.LOG_DEBUG)
            if NAS_HDD3_TEMP ~= nil then dz.devices(NAS_HDD3_TEMP).update(0,results[12]) end
        if results[13] then
            dz.log("HDTemp4 : "..tostring(results[13]),dz.LOG_DEBUG)
            if NAS_HDD4_TEMP ~= nil then dz.devices(NAS_HDD4_TEMP).update(0,results[13]) end
        if results[0] and results[5] and results[6] then
                dz.log("Requete SNMP correcte ",dz.LOG_DEBUG)
                dz.devices(NAS).switchOn().checkFirst()
                dz.log("Requete SNMP incorrecte ",dz.LOG_DEBUG)
                dz.devices(NAS).switchOff().checkFirst()
        --RAID Status :
        --OK(1), Repairing(2), Migrating(3), Expanding(4), Deleting(5), Creating(6), RaidSyncing(7), RaidParityChecking(8), RaidAssembling(9), Canceling(10), Degraded(11), Creashed(12)
Here are the logs of my NAS when the level domoticz.LOG_DEBUG is activated:
2018-08-24 19_06_24-Domoticz.png (17.33 KiB) Viewed 12089 times
sincze
Domoticz version: 2024.4
Re: Monitor Synology NAS with SNMP
Post by sincze »
Tnx. Nice to see somebody managed to move the script towards dzvents. Maybe add it to the Domoticz general wiki as well under Monitor NAS ??
https://www.domoticz.com/wiki/NAS_Monitoring
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
papoo
Post by papoo »
script update
DomoRies
Post by DomoRies »
Thanks for your script! It's easy to install but i get a error in the domoticz log:
2018-09-03 12:22:00.594 Status: dzVents: Error (2.4.7): Synology Monitor v1.03 : An error occured when calling event handler synology
2018-09-03 12:22:00.594 Status: dzVents: Error (2.4.7): Synology Monitor v1.03 : /home/pi/domoticz/scripts/dzVents/scripts/synology.lua:118: attempt to perform arithmetic on field '?' (a string value)
Now it only updates NAS_HD1_TEMP
I'm using domoticz beta version: 4.9980 and Synology nas DS1513+ DSM 6.2-23739 Update 2
freijn
Domoticz version: Stable
Post by freijn »
Very nice job, many thanks !
snellejellep
Post by snellejellep »
it works for some things but i get this error message:
2018-09-03 19:36:00.359 Status: dzVents: Error (2.4.7): Synology Monitor v1.03 : An error occured when calling event handler monitor NAS
2018-09-03 19:36:00.359 Status: dzVents: Error (2.4.7): Synology Monitor v1.03 : ...moticz/scripts/dzVents/generated_scripts/monitor NAS.lua:117: attempt to perform arithmetic on field '?' (a string value)
can someone help me?
papoo
Post by papoo »
comment line 86 level = domoticz.LOG_ERROR, -- Only one level can be active; comment others
uncomment line 87 -- level = domoticz.LOG_DEBUG,
what the result on your log?
if you have a new synology nas try .31
if you want to try in command line before install this script
snellejellep
papoo wrote: Monday 03 September 2018 21:06 comment line 86 level = domoticz.LOG_ERROR, -- Only one level can be active; comment others
that fixed it for me, thanks!
papoo
Post by papoo »
script and help update
Tonio16
Domoticz version: 4.9700
Post by Tonio16 »
Hello
Just one remark. On my DS216Play I am using .42 with the last DSM.
Antoine
SchulieBug
Post by SchulieBug »
I'm getting these errors:
2019-03-26 16:10:00.204 Status: dzVents: Error (2.4.15): Synology Monitor v1.04 : An error occured when calling event handler SynologyNAS
2019-03-26 16:10:00.204 Status: dzVents: Error (2.4.15): Synology Monitor v1.04 : ...cz/var/scripts/dzVents/generated_scripts/SynologyNAS.lua:75: attempt to perform arithmetic on field '?' (a nil value)
Can someone point me in the right direction?
papoo
Post by papoo »
@SchulieBug
can you tell me what is your ligne 75?
the last version of this script is here https://github.com/papo-o/domoticz_scri ... ology2.lua
can you try it?
papoo
Post by papoo »
new version 1.35.
Improvement calculation of the memory used and taking into account the temperature HDD up to 4 disks
FunFair
Post by FunFair »
With DSM7 my 2 disks are located at .1.3.6.1.2.1.25.2.3.1.5.47 and .1.3.6.1.2.1.25.2.3.1.5.48
This instead of .38 or .41
EddyG
Post by EddyG »
For those who connect a APC UPS to the Synology you could use:
    local OID_UPS_STATUS = '1.3.6.1.4.1.6574.4.2.1.0'       -- OID Ups status
    local OID_UPS_RUNTIME = '1.3.6.1.4.1.6574.4.3.6.1.0'    -- OID Ups runtime
    local OID_UPS_CHARGE = '1.3.6.1.4.1.6574.4.3.1.1.0'     -- OID Ups status
    local UPS_Status = ""
                ..OID_UPS_STATUS..' '..OID_UPS_RUNTIME..' '..OID_UPS_CHARGE..' '
        if results[17] then
            if results[17] == '"OL"' then UPS_Status = 'ONLINE'
            elseif results[17] == '"OB"' then UPS_Status = 'ON BATTERY'
            elseif results[17] == '"LB"' then UPS_Status = 'LOW BATTERY'
            elseif results[17] == '"HB"' then UPS_Status = 'HIGH BATTERY'
            elseif results[17] == '"RB"' then UPS_Status = 'REPLACE BATTERY'
            elseif results[17] == '"OL CHRG"' then UPS_Status = 'CHARGING'
            elseif results[17] == '"OB DISCHRG"' then UPS_Status = 'DISCHARGING'
            elseif results[17] == '"BYPASS"' then UPS_Status = 'BYPASS'
            elseif results[17] == '"CAL"' then UPS_Status = 'CALIBRATION'
            elseif results[17] == '"OFF"' then UPS_Status = 'OFF'
            elseif results[17] == '"OVER"' then UPS_Status = 'OVERLOAD'
            elseif results[17] == '"TRIM"' then UPS_Status = 'SMART TRIM'
            elseif results[17] == '"BOOST"' then UPS_Status = 'BOOST'
            elseif results[17] == '"FSD"' then UPS_Status = 'FORCE SHUTDOWN'
            else UPS_Status = 'UNKNOWN'
            dz.log("NAS UPS status : "..tostring(UPS_Status),dz.LOG_DEBUG)
            if NAS_UPS_STATUS ~= nil then dz.devices(NAS_UPS_STATUS).updateText(UPS_Status) end
        if results[18] then
            dz.log("NAS UPS runtime : "..tostring(dz.utils.round(results[18]/60,0)),dz.LOG_DEBUG)
            if NAS_UPS_RUNTIME ~= nil then dz.devices(NAS_UPS_RUNTIME).update(0,dz.utils.round(results[18]/60,0)) end
        if results[19] then
            dz.log("NAS UPS charge : "..tostring(dz.utils.round(results[19],0)),dz.LOG_DEBUG)
            if NAS_UPS_CHARGE ~= nil then dz.devices(NAS_UPS_CHARGE).update(0,dz.utils.round(results[19],0)) end
Change the index (17,18,19) to the real index.
Status is a Text device, Runtime a custom sensor with axis -> mins and Charge is a percentage device.
EddyG
Post by EddyG »
The OID_CpuUser and OID_CpuSystem are momentary values, and vary a lot.
Beter use the one (or more) of the load values:
    local OID_Cpu_1min = '1.3.6.1.4.1.2021.10.1.3.1'
    local OID_Cpu_5min = '1.3.6.1.4.1.2021.10.1.3.2'
    local OID_Cpu_15min = '1.3.6.1.4.1.2021.10.1.3.3'
jeroenkl
Post by jeroenkl »
FunFair wrote: Tuesday 29 June 2021 22:01 With DSM7 my 2 disks are located at .1.3.6.1.2.1.25.2.3.1.5.47 and .1.3.6.1.2.1.25.2.3.1.5.48
On DS920+ with DSM7 it is .57
Last edited by jeroenkl on Friday 17 September 2021 20:53, edited 1 time in total.
EddyG
Post by EddyG »
On DSM 7.0 you can walk 1.3.6.1.2.1.25.2.3.1 and starting 1.3.6.1.2.1.25.2.3.1.31 you will see textual description of the different mounts.
This is part of mine:
01/09/2021 15:30:20 (178 ms) : 1.3.6.1.2.1.25.2.3.1.3.31 = "/" [ASN_OCTET_STR]
01/09/2021 15:30:20 (197 ms) : 1.3.6.1.2.1.25.2.3.1.3.56 = "/volume1" [ASN_OCTET_STR]
Here you can find that my volume1 is on 1.3.6.1.2.1.25.2.3.1.3.56 Yours might differ on the last digits.
The corresponding data for calculating free space is on:
1.3.6.1.2.1.25.2.3.1.4.56  -> Unit
1.3.6.1.2.1.25.2.3.1.5.56  -> Total space
1.3.6.1.2.1.25.2.3.1.6.56  -> Used space
