dzVents and SQL
ChrisKerswell
dzVents and SQL
Post by ChrisKerswell »
Is there any way to use dzVents to run SQL queries directly on the database?
I tried to search the forum for this but the search ignores "SQL" because it is less than four characters :|
Re: dzVents and SQL
ChrisKerswell wrote: Friday 24 August 2018 1:17 Hi,
Not natively but via popen it can be done
   on = { devices = { "your trigger device" }},
  logging =   {   level     =   domoticz.LOG_DEBUG,
                  marker    =   "dataBase query"      },
    execute = function(dz)
        local command = 'sqlite3 tempdatabase.db \"select distinct(DeviceRowID) from Temperature_Calendar\" '
        local handle = assert(io.popen(command))
        for line in handle:lines() do
            dz.log(line,dz.LOG_DEBUG)
        handle:close()
