dzvents after update to version 4.97
Posted: Wednesday 22 August 2018 15:27
by pgas37
Domoticz ver 4.97 on Raspberrypi
The dzvents-script below (ventilator-switch based on a humidity-sensor) worked fine under domoticz-version 3.87. After an update to version 4,97 this script and some others (also based on humidity) do not work anymore. In domoticz version 4.97 the versionnumber of dzvents is not visible anymore.
Th script has a test-mode, but also the test-mode does not work anymore! :cry:
Probably something small, but i cannot find the solution.
Can anybody help?
Paul
	active = true,
        timer = { 'every 30 minutes' }
    data = {
		HumidityBefore = { initial = 50 }
    execute = function(domoticz)
       local debug = true
        function debug_print(MyLine)
            if debug then print(MyLine) end
    local   Vent = domoticz.devices('VentSchakelaarSL1-')                         -
            SENSOR_NAME = 'Zolder TH_ch2'
            TEST_MODE_HUMVAR = 'testHumidity' .. SENSOR_NAME
            vochtpercentage = 60
            PRINT_MODE = true
            Temp = domoticz.devices('').temperature
        --local Humidity = domoticz.devices('Zolder TH_ch2').humidity
        --print(' hum =================================   :' ..Humidity)
    if (tonumber(uservariables[TEST_MODE_HUMVAR]) > 0) then
            current = tonumber(uservariables[TEST_MODE_HUMVAR])
            if PRINT_MODE == true then
            print('Current Humidity Test Mode: ' .. current)
            current = domoticz.devices('Zolder TH_ch2').humidity
            print('Current Humidity: ' ..SENSOR_NAME  .. current)
       if (current == 0 or current == nil) then
            print("dzVents: Zolder Humidity: current is 0 or nil. Skipping this reading")
            print('Current Humidity: ' ..current)
            print('hum before: ' ..domoticz.data.HumidityBefore)
            if ( current >= vochtpercentage) then
                debug_print ("dzventz: Zolder Humidity > dan: " ..vochtpercentage)
                debug_print ("dzVents: Humidity:  "  .. tostring(current)  .. "  domoticz.data.HumidityBefore: " .. tostring(domoticz.data.HumidityBefore ))
                local StartNeeded = ( ( current > vochtpercentage )  and ( Vent.state == 'Off' )  )
                if StartNeeded then
                    print ("dzVents: Zolder Humidity:  Fan off ==>> Switching fan on for 50 minutes")
                    Vent.switchOn()
                    domoticz.notify('vocht% >= 60(script VV-on_off): ', 'Vent. aan 50min: vocht%: ' .. current .. '  Temperatuur: ' ..Temp, domoticz.PRIORITY_LOW)
                    Vent.switchOff().afterMin(50)
                domoticz.data.HumidityBefore = current   --Humidity
Re: dzvents after update to version 4.97
Posted: Wednesday 22 August 2018 15:40
by SweetPants
Does setup->about not show the dz_Vents version? It does on my installation.
Posted: Wednesday 22 August 2018 22:49
by waaren
pgas37 wrote: Wednesday 22 August 2018 15:27 Domoticz ver 4.97 on Raspberrypi
Are you sure this script worked in other versions ?
Do you see anything in the log ?
The two lines below will give errors
   local   Vent = domoticz.devices('VentSchakelaarSL1-')                         -   ??? This single - will cause  unexpected symbol error
    Temp = domoticz.devices('').temperature                               ???? This empty string will cause a problem with the device-adapter
Posted: Thursday 23 August 2018 14:34
by pgas37
I found the versionnumber: dzvents 2.4.6 and
Indeed between the ' ' a sensor was mentioned so no errors occured (Temp = domoticz.devices('Zolder TH_ch2').temperature)
The single - in Local, Vent = domoticz.devices('VentSchakelaarSL1-') did not give any problem and
I am sure the script worked!
Could it be a cache problem? How to flush cache(s) in Domoticz?
Posted: Thursday 23 August 2018 14:38
by waaren
pgas37 wrote: Thursday 23 August 2018 14:34 I found the versionnumber: dzvents 2.4.6 and
I was not referring to the - between the quotes but to a single - probably left behind after removing a comment on the same line. Lua will not accept such a single - in the middle of your script and therefore dzVents cannot continue with the execution of this script.
Cache can only be a problem in the gui not with execution of any script.
What is in the log ?
Posted: Thursday 23 August 2018 15:39
by pgas37
I found out that the script works again if I remove the 'test'-part of the script:
=== removed
For some reason the user-variable "TEST_MODE_HUMVAR' (type variable = integer) causes the trouble.
A nil value error.
Any suggestion?
Paul
Log-file
2018-08-23 15:29:00.540 Status: dzVents: Info: ========================================= Vocht meting Zolder test
2018-08-23 15:29:00.561 Status: dzVents: Info: === Vocht meting Zolder test Sensor: Zolder TH_ch2
2018-08-23 15:29:00.561 Status: dzVents: Info: === Vocht meting Zolder test TEMPHUMVAR: testHumidity Zolder TH_ch2
2018-08-23 15:29:00.561 Status: dzVents: Info: === Vocht meting Zolder test Vocht% ingesteld : 60
2018-08-23 15:29:00.561 Status: dzVents: Info: === Vocht meting Zolder test. TEMP-actueel : 25.39999961853
2018-08-23 15:29:00.561 Status: dzVents: Info: === Vocht meting Zolder test. Vocht_actueel : 62
2018-08-23 15:29:00.562 Status: dzVents: Error (2.4.6): An error occured when calling event handler VochtVentdV-on_off test
2018-08-23 15:29:00.562 Status: dzVents: Error (2.4.6): ...ts/dzVents/generated_scripts/VochtVentdV-on_off test.lua:44: attempt to index global 'uservariables' (a nil value)
2018-08-23 15:29:00.562 Status: dzVents: Info: ------ Finished VochtVentdV-on_off test
Posted: Thursday 23 August 2018 16:53
by waaren
pgas37 wrote: Thursday 23 August 2018 15:39 I found out that the script works again if I remove the 'test'-part of the script:
=== removed
Change uservariables to domoticz.uservariables
Posted: Thursday 23 August 2018 19:33
by pgas37
I changed the uservariable.
The error (nil-value) is solved, but as long as the test-mode part is within the script, the script stops further execution. So all log-message before the test-mode part are visible, after the test-mode part the script seems dead.
Remove the test-mode part and the scripts works fine.
So what is de diffrence for this part of the script under this dzvents(2.4.6) in comparision with the version before the update?
thanks for your help.
regards
Paul
eturn {
	active = true,
        timer = {'every minute'}                                           --'every 30 minutes' }
    data = {
		HumidityBefore = { initial = 51 }
       local debug = true
    domoticz.log(' ========================================= Vocht meting Zolder test')
    local   Vent = domoticz.devices('VentSchakelaarSL1-')                             --('Schakelaar zolder (elro Ch D1)')                        --('ChntpB2')                   --
            TEST_MODE_HUMVAR = 'testHumidity ' .. SENSOR_NAME
            PRINT_MODE = true
        --local Humidity = domoticz.devices('Digoo_ch1').humidity
        --print(' hum   :' ..Humidity)
            print('locals===============================================')
        domoticz.log('=== Vocht meting Zolder test  Sensor: ' ..SENSOR_NAME)
        domoticz.log('=== Vocht meting Zolder test TEMPHUMVAR: ' ..TEST_MODE_HUMVAR)
        domoticz.log('=== Vocht meting Zolder test  Vocht% ingesteld : ' ..vochtpercentage)
        domoticz.log('=== Vocht meting Zolder test. TEMP-actueel :  ' ..Temp)
        domoticz.log('=== Vocht meting Zolder test. Vocht_actueel :  ' ..current)
--==========================test mode===========================
    if (tonumber(domoticz.uservariables[TEST_MODE_HUMVAR]) > 0) then
         current = tonumber(domoticz.uservariables[TEST_MODE_HUMVAR])
 --========================einde test mode ============================
        print('Current Humidity ==== 1 : ' ..SENSOR_NAME  .. current)
            print('=====Current Humidity ====2 : ' ..current)
            print('=====hum before: ' ..domoticz.data.HumidityBefore)
                if StartNeeded then
                    Vent.switchOn()
                print('=== HumidityBefore -einde script- : ' ..current)
Posted: Thursday 23 August 2018 20:37
by waaren
pgas37 wrote: Thursday 23 August 2018 19:33 I changed the uservariable.
Don't know of any relevant differences but if you look at logfile you will see where the script fail.
the dzVents syntax to get the value of a domoticz uservar is domoticz.variables("name of uservar").value
maybe my simplified ventilator activation script can help you.
 -- Bathroom humidity.lua
    on = { timer = { 'every minute' }},
    data = { humidityBefore = { history = true, maxItems = 10 }},
--    logging =   {   level   =   domoticz.LOG_DEBUG,
--                    marker  =   "Bathroom humidity" },
    execute = function(dz)
        local humidity          = dz.devices("Badkamer (Zwave)").humidity
        local vent              = dz.devices('Centrale afzuiging')
        if dz.data.humidityBefore.getOldest() == nil then
          dz.data.humidityBefore.add(99)
        local humidityBefore    = dz.data.humidityBefore.getOldest().data 		-- value from 10 minutes ago
        if humidity == nil or humidity == 0 then
            dz.log("current is 0 or nil. Skipping this reading",dz.LOG_ERROR)
            return
        dz.log(humidity  .. "  HumidityBefore: " .. humidityBefore,dz.LOG_DEBUG)
        if  humidity ~= humidityBefore  then
            if humidity > 65 and humidity > ( humidityBefore + 3)  and vent.state == 'Off' then
                dz.log("Fan off ==>> Switching fan on for 20 minutes",dz.LOG_FORCE)
                vent.switchOn().repeatAfterSec(10,2) -- Repeat command 2 times (after 10 and 20 seconds)
                vent.switchOff().afterMin(20).repeatAfterSec(10,2)
        dz.data.humidityBefore.add(humidity)
Posted: Saturday 25 August 2018 17:34
by pgas37
Oke,
I will try your script, but it does not solve the “test-part” problem in the script with the user-variable that didn’t exits before!
Posted: Tuesday 28 August 2018 15:42
by dannybloe
Accessing a user variable in dzVents is done like this:
domoticz.variables('myUserVar').value
No need to convert it so number if the variable is defined as such in the GUI.
Posted: Tuesday 28 August 2018 17:37
by pgas37
I understand “ no need to convert it”( the tonumber(xx)) , but i do not understand te rest of your sentence.....
Re: dzvents after update to version 4.97  [SOLVED]
Posted: Tuesday 28 August 2018 17:52
by dannybloe
The type of the variable is defined in domoticz when you created the uservariable. So if it is a number or integer type it will be the same in dzVents.
Posted: Tuesday 28 August 2018 19:19
by pgas37
Thx
