Errors building with telldus support
jornm
Post by jornm »
Version: latest from git
Platform: Raspberry Pi 3 b+, running NOOBS and with updated firmware.
I get errors when building latest version from git (git pull) when I have telldus installed.
[ 39%] Building CXX object CMakeFiles/domoticz.dir/hardware/Thermosmart.cpp.o
In file included from /root/dev-domoticz/hardware/Tellstick.cpp:3:0:
/root/dev-domoticz/hardware/Tellstick.h:20:33: error: expected ‘)’ before ‘genSwitch’
Command(_tGeneralSwitch genSwitch)
I have searched the forums (and with google) to see if any others have had this problem but not found anything.
Output from cmake:
root@mypi:~/dev-domoticz#  cmake -DCMAKE_BUILD_TYPE=Release CMakeLists.txt
-- Compiling Revision #9921
-- Using builtin Mosquitto library
-- Python3 includes found at: /usr/include/python3.4m
-- Building with I2C support
-- Building with SPI support
-- OPENSSL_LIBRARIES: /usr/lib/arm-linux-gnueabihf/libssl.a;/usr/lib/arm-linux-gnueabihf/libcrypto.a
CMake Warning at /usr/share/cmake-3.6/Modules/FindBoost.cmake:743 (message):
  Imported targets not available for Boost version 106800
Call Stack (most recent call first):
  /usr/share/cmake-3.6/Modules/FindBoost.cmake:842 (_Boost_COMPONENT_DEPENDENCIES)
  /usr/share/cmake-3.6/Modules/FindBoost.cmake:1411 (_Boost_MISSING_DEPENDENCIES)
  CMakeLists.txt:573 (find_package)
-- Boost version: 1.68.0
-- Found the following Boost libraries:
--   thread
--   system
-- Linking against boost static libraries
-- ZLIB libraries found at: /usr/lib/arm-linux-gnueabihf/libz.so
-- ZLIB includes found at: /usr/include
-- Curl libraries found at: /usr/lib/arm-linux-gnueabihf/libcurl.so
-- Curl includes found at: /usr/include
-- LIBUSB found at: /usr/lib/arm-linux-gnueabihf/libusb.so
-- /root/open-zwave-read-only/libopenzwave.a
-- /usr/lib/arm-linux-gnueabihf/libudev.so
-- GPIO is available
-- Found telldus-core (telldus-core.h) at : /usr/include
-- Found libtelldus-core at : /usr/lib/libtelldus-core.so, adding telldus support
/usr/bin/c++  ;;-std=c++11;-O3;-DNDEBUG;-I/usr/include/python3.4m;-I/root/dev-domoticz/main;-I/root/dev-domoticz/tinyxpath;-I/usr/include;-I/usr/local/include;-I/usr/include;-I/root/dev-domoticz/zip;-I/usr/include;-I/root/dev-domoticz/hardware/openzwave;-DBUILTIN_MQTT;-DENABLE_PYTHON;-DHAVE_EXECINFO_H;-DHAVE_LINUX_I2C;-DHAVE_LINUX_SPI;-DWWW_ENABLE_SSL;-DWITH_LIBUSB;-DWITH_OPENZWAVE;-DWITH_GPIO;-DWITH_TELLDUSCORE -x c++-header -o /root/dev-domoticz/stdafx.h.gch/.c++ /root/dev-domoticz/main/stdafx.h
-- Using static libgcc/libstdc++
-- Configuring done
-- Generating done
-- Build files have been written to: /root/dev-domoticz
jornm
Re: Errors building with telldus support
Post by jornm »
I have now fixed the boost library warnings from cmake. Had to upgrade cmake to latest version because there is a version dependency between boost version and cmake version. But that did not help with the error I get when compiling domoticz with telldus support.
jornm
Post by jornm »
I think that this error might be the root cause for the issues:
/root/dev-domoticz/hardware/Tellstick.h:19:31: error: ‘get_system_time’ is not a member of ‘boost’
               repeatTimePoint(boost::get_system_time()) {}
Looks like the Tellstick.h is not compatible with latest boost libraries (v1.68)
A more complete output of error messages:
[ 20%] Building CXX object CMakeFiles/domoticz.dir/hardware/XiaomiGateway.cpp.o
/root/dev-domoticz/hardware/Tellstick.h:25:9: error: ‘_tGeneralSwitch’ does not name a type
         _tGeneralSwitch genSwitch;
/root/dev-domoticz/hardware/Tellstick.h:27:16: error: ‘system_time’ in namespace ‘boost’ does not name a type
         boost::system_time repeatTimePoint;
/root/dev-domoticz/hardware/Tellstick.h:43:39: error: ‘_tGeneralSwitch’ does not name a type
     void SendCommand(int devID, const _tGeneralSwitch &cmd);
/root/dev-domoticz/hardware/Tellstick.h:56:12: error: ‘posix_time’ in namespace ‘boost’ does not name a type
     boost::posix_time::milliseconds m_repeatInterval;
/root/dev-domoticz/hardware/Tellstick.h: In constructor ‘CTellstick::Command::Command()’:
/root/dev-domoticz/hardware/Tellstick.h:19:15: error: class ‘CTellstick::Command’ does not have any field named ‘repeatTimePoint’
/root/dev-domoticz/hardware/Tellstick.cpp: In constructor ‘CTellstick::CTellstick(int, int, int)’:
/root/dev-domoticz/hardware/Tellstick.cpp:19:7: error: class ‘CTellstick’ does not have any field named ‘m_repeatInterval’
       m_repeatInterval(repeatInterval)
/root/dev-domoticz/hardware/Tellstick.cpp: In member function ‘void CTellstick::SetSettings(int, int)’:
/root/dev-domoticz/hardware/Tellstick.cpp:29:5: error: ‘m_repeatInterval’ was not declared in this scope
     m_repeatInterval = boost::posix_time::milliseconds(repeatInterval);
/root/dev-domoticz/hardware/Tellstick.cpp: In member function ‘virtual bool CTellstick::WriteToHardware(const char*, unsigned char)’:
/root/dev-domoticz/hardware/Tellstick.cpp:41:47: error: no matching function for call to ‘CTellstick::Command::Command(const _tGeneralSwitch&)’
     m_commands[pSwitch->id] = Command(*pSwitch);
/root/dev-domoticz/hardware/Tellstick.cpp:41:47: note: candidates are:
/root/dev-domoticz/hardware/Tellstick.h:17:9: note: CTellstick::Command::Command()
         Command()
/root/dev-domoticz/hardware/Tellstick.h:17:9: note:   candidate expects 0 arguments, 1 provided
/root/dev-domoticz/hardware/Tellstick.h:15:12: note: constexpr CTellstick::Command::Command(const CTellstick::Command&)
     struct Command
/root/dev-domoticz/hardware/Tellstick.h:15:12: note:   no known conversion for argument 1 from ‘const _tGeneralSwitch’ to ‘const CTellstick::Command&’
/root/dev-domoticz/hardware/Tellstick.h:15:12: note: constexpr CTellstick::Command::Command(CTellstick::Command&&)
/root/dev-domoticz/hardware/Tellstick.h:15:12: note:   no known conversion for argument 1 from ‘const _tGeneralSwitch’ to ‘CTellstick::Command&&’
/root/dev-domoticz/hardware/Tellstick.cpp: In member function ‘virtual bool CTellstick::StopHardware()’:
/root/dev-domoticz/hardware/Tellstick.cpp:241:18: error: ‘class std::shared_ptr<std::thread>’ has no member named ‘joinable’
     if (m_thread.joinable())
/root/dev-domoticz/hardware/Tellstick.cpp:242:18: error: ‘class std::shared_ptr<std::thread>’ has no member named ‘join’
         m_thread.join();
/root/dev-domoticz/hardware/Tellstick.cpp: At global scope:
/root/dev-domoticz/hardware/Tellstick.cpp:246:6: error: prototype for ‘void CTellstick::SendCommand(int, const _tGeneralSwitch&)’ does not match any in class ‘CTellstick’
 void CTellstick::SendCommand(int devID, const _tGeneralSwitch &genSwitch)
/root/dev-domoticz/hardware/Tellstick.h:43:10: error: candidate is: void CTellstick::SendCommand(int, const int&)
/root/dev-domoticz/hardware/Tellstick.cpp: In member function ‘void CTellstick::ThreadSendCommands()’:
/root/dev-domoticz/hardware/Tellstick.cpp:274:45: error: ‘m_repeatInterval’ was not declared in this scope
         boost::system_time nextTime = now + m_repeatInterval;
/root/dev-domoticz/hardware/Tellstick.cpp:275:14: error: ‘map’ was not declared in this scope
         for (map<int, Command>::iterator it = m_commands.begin();
/root/dev-domoticz/hardware/Tellstick.cpp:275:14: note: suggested alternative:
In file included from /usr/include/c++/4.9/map:61:0,
                 from /root/dev-domoticz/main/stdafx.h:46:
/usr/include/c++/4.9/bits/stl_map.h:96:11: note:   ‘std::map’
     class map
/root/dev-domoticz/hardware/Tellstick.cpp:275:18: error: expected primary-expression before ‘int’
/root/dev-domoticz/hardware/Tellstick.cpp:276:14: error: ‘it’ was not declared in this scope
              it != m_commands.end();
/root/dev-domoticz/hardware/Tellstick.cpp:301:20: error: ‘class std::condition_variable’ has no member named ‘timed_wait’
             m_cond.timed_wait(lock, nextTime);
/root/dev-domoticz/hardware/Tellstick.cpp: In member function ‘void http::server::CWebServer::Cmd_TellstickApplySettings(http::server::WebEmSession&, const http::server::request&, Json::Value&)’:
/root/dev-domoticz/hardware/Tellstick.cpp:316:13: error: ‘string’ was not declared in this scope
             string hwIdStr = request::findValue(&req, "idx");
/root/dev-domoticz/hardware/Tellstick.cpp:316:13: note: suggested alternative:
In file included from /usr/include/c++/4.9/string:39:0,
                 from /root/dev-domoticz/main/stdafx.h:17:
/usr/include/c++/4.9/bits/stringfwd.h:62:33: note:   ‘std::string’
   typedef basic_string<char>    string;
/root/dev-domoticz/hardware/Tellstick.cpp:317:20: error: expected ‘;’ before ‘repeatsStr’
             string repeatsStr = request::findValue(&req, "repeats");
/root/dev-domoticz/hardware/Tellstick.cpp:318:20: error: expected ‘;’ before ‘repeatIntervalStr’
             string repeatIntervalStr = request::findValue(&req, "repeatInterval");
/root/dev-domoticz/hardware/Tellstick.cpp:320:17: error: ‘hwIdStr’ was not declared in this scope
             if (hwIdStr.empty() || repeatsStr.empty() || repeatIntervalStr.empty())
/root/dev-domoticz/hardware/Tellstick.cpp:320:36: error: ‘repeatsStr’ was not declared in this scope
/root/dev-domoticz/hardware/Tellstick.cpp:320:58: error: ‘repeatIntervalStr’ was not declared in this scope
/root/dev-domoticz/hardware/Tellstick.cpp:323:29: error: ‘hwIdStr’ was not declared in this scope
             int hwID = atoi(hwIdStr.c_str());
/root/dev-domoticz/hardware/Tellstick.cpp:324:32: error: ‘repeatsStr’ was not declared in this scope
             int repeats = atoi(repeatsStr.c_str());
/root/dev-domoticz/hardware/Tellstick.cpp:325:39: error: ‘repeatIntervalStr’ was not declared in this scope
             int repeatInterval = atoi(repeatIntervalStr.c_str());
CMakeFiles/domoticz.dir/build.make:2116: recipe for target 'CMakeFiles/domoticz.dir/hardware/Tellstick.cpp.o' failed
make[2]: *** [CMakeFiles/domoticz.dir/hardware/Tellstick.cpp.o] Error 1
make[2]: *** Waiting for unfinished jobs....
[ 21%] Building CXX object CMakeFiles/domoticz.dir/hardware/Yeelight.cpp.o
CMakeFiles/Makefile2:114: recipe for target 'CMakeFiles/domoticz.dir/all' failed
make[1]: *** [CMakeFiles/domoticz.dir/all] Error 2
Makefile:151: recipe for target 'all' failed
I am not a developer so I hope someone with that skill can help. Any takers?
jornm
Post by jornm »
I have now tried to install on a second RPi 3 B+, this time with clean installation of respbian and following the guides in wiki, but still gets the same error when trying to build with telldus support. Building without telldus works just fine. Which makes me wonder: Have anyone ever succeeded building with telldus support with the current version? If so, which boost library version was used?
Adelgren
Post by Adelgren »
I'm getting the exact same problem while compiling:
[ 67%] Building CXX object CMakeFiles/domoticz.dir/hardware/Tellstick.cpp.o
In file included from /home/pi/dev-domoticz/hardware/Tellstick.cpp:3:0:
/home/pi/dev-domoticz/hardware/Tellstick.h:20:33: error: expected ‘)’ before ‘genSwitch’
/home/pi/dev-domoticz/hardware/Tellstick.h:25:9: error: ‘_tGeneralSwitch’ does not name a type
/home/pi/dev-domoticz/hardware/Tellstick.h:27:16: error: ‘system_time’ in namespace ‘boost’ does not name a type
I have boost version 1.64 installed on my system.
Can a developer have a look at this? Tellstick is a must for my system.
jornm
Post by jornm »
The instructions in http://www.domoticz.com/wiki/Raspberry_ ... rom_source is not complete. It gives instructions on how to build boost libraries, but fails to mention that you need to build latest version of cmake to be able to actually use the boost version you build.
I found this: https://askubuntu.com/questions/355565/ ... mmand-line
Brows down to "Building and Installing (recommended)" and follow that to buld a cmake version that actually works with the latest boost library
However, it's not enough to do this to fix the issue with building telldus support... I think there is missing some include/refrences to either the date_time or chrono boost library to get telldus support to work. Any developers out there that can look into this please?
jornm
Post by jornm »
I just tried to compile an older version of hardware/Tellstic.cpp and hardware/Tellstick.h
git checkout d6f392cfaddfae1fdbe680d0ece8b2de0b10a8ff hardware/Tellstick.cpp
git checkout d6f392cfaddfae1fdbe680d0ece8b2de0b10a8ff hardware/Tellstick.h
and then: make
It compiles, but I have not yet tested if it works.
I'll try to build with never versions until it fails again...
jornm
Post by jornm »
It is this commit that broke the telldus support:
https://github.com/domoticz/domoticz/co ... f192a15f4b
Latest version that compiles is this:
git checkout cd212245fdcfcef3440522abdcde3162c039a685 hardware/Tellstick.cpp
git checkout cd212245fdcfcef3440522abdcde3162c039a685 hardware/Tellstick.h
hummel
Post by hummel »
Works for me, thanks a lot!
jornm wrote: Thursday 30 August 2018 12:11 It is this commit that broke the telldus support:
