Jula Anslut plugin 408060 on/off 1000W 433.92 mhz
Posted: Friday 17 August 2018 19:52
by Sway06
How can I find this wallplug in Domoticz when using Rfxtrx433E transceiver? I don't have any remote control and when I use the learn switch function and click on the plug button it just times out and does not recognize it. Thanks for your help!
Re: Jula Anslut plugin 408060 on/off 1000W 433.92 mhz
Posted: Saturday 18 August 2018 10:27
by b_weijenberg
check with RFXmngr if you can pair it using Lighting2 - Anslut and try with a few different ID's
reset the module to remove all paired remotes.
Posted: Sunday 19 August 2018 22:22
by bjacobse
Why not purchase a new set from Jula, SEK 149 (might be easiest and fastest)
and then you get 2 wallplugs and a remote. then you can use the remote to program your Rfxtrx433 gateway
https://www.jula.se/catalog/el-och-bely ... re-408084/
Posted: Monday 03 December 2018 21:13
by Sway06
Thanks for your replies. I bought newer switches from Telldus that are smaller and worked like a charm.
